http://www.youtube.com/watch?v=1Tdz7vSI6To
It sure is totally orginal mono-motronic! i just made small adjustments listed below:
- Larger Injector from a Volvo 740
- Secondary Bosch 5 bar fuelpump from Saab 900 turbo, after orginal fuelpump
- Malpassi 384HR progressive fuelpressure regulator
Fuel pressure is from 0,7bar up to 2,2bar, orginal is max 1,1bar. Ecu is orginal and works because the charge pressure is so low, 0,4bar. It is possible to charge up to 0,7 with mono-motronic without changing anything. But broadband lamda should beadded, it will work much better with it. So everything is orginal and no special adjustments done. It is possible to make the car to orginal in 30 minutes.
Ха сега.. скоро май ще го пробваме това нещо
