Golf MK4 бушони?
- Регистриран на: Нед 02 яну 2011 16:15
- Местоположение: haskovo
Golf MK4 бушони?
искам да попитам кои от всичките бушони е за зумера[img]C:\Documents%20and%20Settings\user\Desktop\Изображение0041.jpg[/img]
- brabus
- R-циклопедист на VW
- Регистриран на: Вто 08 юни 2004 8:17
- Автомобил: Golf II GTI PB A4 Avant 1.8 TQ
- Двигател: 1991 2003
Re: бушони за голф 4
Кой зумер? Едва ли има отделен бушон само за зумер.
VW Golf GTI Mk IV Fuse List
1. Washer nozzle heaters, glove compartment light, memory seat control module (10A).
2. Turn signal lights (10A).
3. Fog light relay, instrument panel light dimmer switch (5A).
4. License plate light (5A).
5. Comfort system, cruise control, Climatronic, A/C, heated seat control modules, automatic day/night interior mirror, control module for multi-function steering wheel, control unit in steering wheel (7.5A).
6. Central locking system (5A).
7. Back-up lights, speedometer vehicle speed sensor (VSS) (10A).
8. Open
9. Anti-lock brake system (ABS) (5A).
10. Engine control module (ECM): gasoline engine (10A); diesel engine, Model Year 2000 > (5A).
11. Instrument cluster, shift lock solenoid (5A).
12. Data Link Connector (DLC) power supply (7.5A).
13. Brake tail lights (10A).
14. Interior lights, central locking system (10A).
15. Instrument cluster, transmission control module (TCM) (5A).
16. A/C clutch, after-run coolant pump (10A).
17. Open.
18. Headlight high beam, right (10A).
19. Headlight high beam, left (10A).
20. Headlight low beam, right (15A).
21. Headlight low beam, left (15A).
22. Parking lights right, side marker right (5A).
23. Parking lights left, side marker left (5A).
24. Windshield and rear window washer pump, windshield wiper motor (20A).
25. Fresh air blower, Climatronic, A/C (25A).
26. Rear window defogger (25A).
27. Motor for rear windshield wiper (15A).
28. Fuel pump (FP) (15A).
29. Engine control module (ECM) gasoline engine (15A); diesel engine (10A).
30. Power sunroof control module (20A).
31. Transmission control module (TCM) (20A).
32. Injectors: gasoline engine (10A); diesel engine (15A).
33. Headlight washer system (20A).
34. Engine control elements (10A).
35. 12 V power outlet (in luggage compartment) (30A).
36. Fog lights (15A).
37. Terminal (86S) on radio, Instrument cluster (10A).
38. Central locking system (with power windows), luggage compartment light, remote/fuel tank door, motor to unlock rear lid (15A).
39. Emergency flashers (15A).
40. Dual tone horn (20A).
41. Cigarette lighter (15A).
42. Radio (25A).
43. Engine control elements (10A).
44. Heated seats (15A).
http://mit.edu/dennis/www/vw/fuses.html
8. Open
17. Open.
42. Radio (25A).
- dragozow
- Регистриран на: Нед 02 ное 2008 8:12
Микроключето в твоята врата е проблема със зумера. Аз чакам един колега да се прибере в София да ми оправи моето. Ако има някой да го оправи плащам си и черпя бира.
- zelkata_ok1_
- Регистриран на: Пон 30 ное 2009 12:43
- Местоположение: sofia
dragozow написа:Микроключето в твоята врата е проблема със зумера. Аз чакам един колега да се прибере в София да ми оправи моето. Ако има някой да го оправи плащам си и черпя бира.
а имаш ли си микроключе
http://prikachi.com/images/758/2817758R.jpg това са бушоните и сега ако някой можи да ми кажи кой от всичките е за зумера на късите светлини
- dragozow
Не, не знам и от къде да купя защото при вносителя е комплект с.....бравата?!?!
Чувал съм че колеги купуват други и ги кръщават нещо.
- brabus
Искаш да изключиш зумера на забравени светлини ли?
Ако отговорът е да - това става през VAGCOM, а не през бушон.
не не ми пищи като са включени фаровете и за тва искам да пробвам да сменя бушона
- brabus
По същия начин - зумерът се включва през ВАГКОМ
- VW Golf 4 1.8T - GTI
- Регистриран на: Сря 17 ное 2010 20:57
- Местоположение: Sofia
искам да питам преди месец и нещо си купих голф 4 ама няма никакъв звук при забравени габарити ( при отворена врата ). Може ли да е изключен или е повреден ( и къде точно се намира ) Мерси предварително
- k_garchev
- Регистриран на: Съб 08 мар 2008 13:12
- Автомобил: VW Golf 4 2.3V5 4motion
- Двигател: AGZ
- Местоположение: Пирдоп
VW Golf 4 1.8T - GTI написа:искам да питам преди месец и нещо си купих голф 4 ама няма никакъв звук при забравени габарити ( при отворена врата ). Може ли да е изключен или е повреден ( и къде точно се намира ) Мерси предварително!
Проблема ти е в микроключето!Има много изписани теми!
- deversant
- Регистриран на: Пон 06 ное 2006 23:58
Ще ползвам темата на колегата,да попитам.31-ви бушон ми липсва.Забелязвам го чак сега,след като отворих за да сменя бушона за запалката.Явно го няма,от както съм купил колата-нов внос.Каква може да е пречината да са го махнали?Възможно ли е да е свързано с abs,защото мисля че може да имам проблем с абс-а?Тази усивителна в комбинация с кой други лампи светва?Мисля,че в комбинация с износени накладки и некви други случай.Но въпросът е...Все още не съм слагал бушон там да видя дали,ще изпише някаква грешка.
- pedalchobaba
- Регистриран на: Вто 01 юли 2008 14:30
Deversant, 31-ви бушон е 20 А и е за захранването на електронния блок управляващ автоматична скоростна кутия. Направи си изводите. И да сложиш бушон там, нищо няма да стане.
Червената удивителна светва в комбинация със себе си. Може да означава различни неща - дръпната ръчна, намалено ниво на спирачната течност ... при някои табла тези две контроли са на отделни индикации. Иначе износените накладки е жълта контрола. ABS-а също, но тя съвсем друга лампа.
Някой може ли да ми каже дали има бушон за зумера и ако има, да ми каже кой номер е.
izvinqvam se za latinicata nqkoi moji li da mi kaji dali ima bushon za zumerai ako znai da mi kaji koi nomer e
Последна промяна от EliPavlova на Пон 03 яну 2011 8:52, променено общо 1 път.
Причина: Кирилица!
Причина: Кирилица!
- pedalchobaba
Колега, зумера е в таблото и май вече ти отговориха, че няма отделен бушон за него.
Освен, че не се задейства при включени светлини, провери ли дали ти светва плафона при отворена шофьорска врата? Защото май и това ти подсказаха, за микро ключето, ама ти не отговори.
Как го проверяваш зумера? При "забравени" светлини и отваряне на вратата зумера няма да се обади, докато не извадиш ключа от контакта ...
Ей такива едни доуточнения са нужни, а ти не отговаряш и само питаш едно и също ...
