Схема бушони-Голф4
eliantonova
Регистриран на: Сря 29 сеп 2010 20:07
Местоположение: rakovski
Схема бушони-Голф4
Мнениеот eliantonova » Вто 20 сеп 2011 13:21
Здравейте, колеги! Някой можели да ми каже как се разчита схемата на бушоните? Благодаря!
baivan
Регистриран на: Вто 06 фев 2007 13:49
Автомобил: Vento
Двигател: 1.8T
Местоположение: Разлог
Re: Схема бушони-Голф4
Мнениеот baivan » Вто 20 сеп 2011 14:38
Fuses:
1 - Washer nozzle heaters, glove compartment light, memory seat control module 10A
2 - Turn signal lights 10A
3 - Fog light relay, instrument panel light dimmer switch 5A
4 - License plate light 5A
5 - Comfort system 7.5A
6 - Central locking system 5A
7 - Back-up lights, speedomter vehicle speed sensor 10A
8 - Open
9 - ABS 5A
10 - Engine control module (ECM), gasoline 10A - Engine control module (ECM), diesel 5A
11 - Instrument cluster, shift lock 5A
12 - Data link connector (DLC) power supply 7.5A
13 - Brake lights 10A
14 - Interior lights, central locking system 10A
15 - Instrument cluster, automatic transmission 5A
16 - A/C-clutch, after-run coolant pump 10A
17 - Open
18 - Right headlight, high beam 10A
19 - Left headlight, high beam 10A
20 - Right headlight, low beam 15A
21 - Left headlight, low beam 15A
22 - Parking & sidemarker lights, right 5A
23 - Parking & sidemarker lights, left 5A
24 - Windshield and rear window washer pump, winshield wiper motor 20A
25 - Fresh air blower, cimatronic, air conditioning 25A
26 - Rear window defogger 25A
27 - Motor for rear windshield wiper 15A
28 - Fuel pump (FP) 15A
29 - Engine control module (ECM), gasoline 15A - Engine control module (ECM), diesel 10A
30 - Sunroof 20A
31 - Automatic transmission 20A
32 - Engine control, injectors, gasoline 10A - Engine control module (ECM), diesel 15A
33 - Headlight washer system 20A
34 - Engine control elements 10A
35 - 12V power outlet (in luggage compartment) 30A
36 - Fog lights 15A
37 - Terminal (86S) on radio, instrument cluster 10A
38 - Central locking system (with power windows), luggage compartment light, remote/fuel tank door, motor to unlock rear lid 15A
39 - Emergency flasher system 15A
40 - Dual horn 20A
41 - Cigarette lighter 15A
42 - Radio system 25A
43 - Engine control elements 10A
44 - Heated seats 15A
eliantonova
Мнениеот eliantonova » Вто 20 сеп 2011 14:49
Благодаря,колега! :applause:
GREEN_lADY
Регистриран на: Нед 11 май 2008 21:02
Мнениеот GREEN_lADY » Сря 21 сеп 2011 7:55
Полезна тема ! :deal
barutchiev
Регистриран на: Пет 29 май 2015 18:12
Автомобил: VW BORA
Двигател: AUS 2000
Мнениеот barutchiev » Нед 09 яну 2022 14:28
Здравейте съфорумци.Знам,че има на доста места снимки на предпазителите ни,но на повечето места са на английски,а не всеки си ги превежда.Реших да кача една снимка от книгата за експлоатация,ремонт и поддръжка на Голф 4/Бора/Джета. Мисля,че е бях качвал и в някоя друга тема пак,но тази е по-специфична и може да помогне на някой.Съжалявам за качеството,но е от телефон,а нямам скенер
ПП.Най-добре се вижда,като се отвори линка за споделяне на снимки и се избере "Изтегляне на оригинала". Тогава вече лесно се зумва,че шрифта е доста дребен
Потребители, разглеждащи този форум: ZEDYCUS и 92 госта
