аз ще умра красиво от ръката на човек на изкуството:
While attending a renaissance fair, you're bludgeoned to
with a lute by a crazed minstrel.
in your car. Your dead body isn't discovered until the following morning. "
Не е важно как ще умреш-важното е как си живял!!!
Оооооооо градски - адаш и аз кат теб ке умра - Winner25 написа:As the unfortunate target of a serial killer, a rope is tied around your wrists, and a second rope is tied around your ankles. The ropes are tied together and hung on a hook from the ceiling, leaving you suspended facing the ground. Concrete blocks are placed onto your back until the weight becomes so great, your arms and legs are torn from your body.
Ще бъдаблагодарен ако някой може да ми го преведе.
Благодаря предварително
