Здравейте, колеги! Ще ви покажа няколко обяви, на които съм се спрял, но не разбирам на 100%. Споделете вашите мнения и препоръки, колко би ми струвало всичко накрая и как би стоял въпроса с годишния данък? :)
http://suchen.mobile.de/auto-inserat/mazda-rx-8-challenge-sindelfingen/191334229.html?lang=en&pageNumber=4&__lp=4&scopeId=C&sortOption.sortBy=searchNetGrossPrice&makeModelVariant1.makeId=16800&makeModelVariant1.modelId=20&makeModelVariant1.searchInFreetext=false&makeModelVariant2.searchInFreetext=false&makeModelVariant3.searchInFreetext=false&minPowerAsArray=110&minPowerAsArray=KW&fuels=PETROL&minPrice=6000&maxPrice=7000&damageUnrepaired=ALSO_DAMAGE_UNREPAIRED&export=ALSO_EXPORT
http://suchen.mobile.de/auto-inserat/mazda-rx-8-revolution-231-ps-lederausstattung-l-xenon-berlin/193270903.html?lang=en&pageNumber=4&__lp=4&scopeId=C&sortOption.sortBy=searchNetGrossPrice&makeModelVariant1.makeId=16800&makeModelVariant1.modelId=20&makeModelVariant1.searchInFreetext=false&makeModelVariant2.searchInFreetext=false&makeModelVariant3.searchInFreetext=false&minPowerAsArray=110&minPowerAsArray=KW&fuels=PETROL&minPrice=6000&maxPrice=7000&damageUnrepaired=ALSO_DAMAGE_UNREPAIRED&export=ALSO_EXPORT
http://suchen.mobile.de/auto-inserat/mazda-rx-8-revolution-141kw-berlin-schöneberg/189012354.html?lang=en&pageNumber=12&__lp=61&scopeId=C&sortOption.sortBy=searchNetGrossPrice&makeModelVariant1.makeId=16800&makeModelVariant1.searchInFreetext=false&makeModelVariant2.searchInFreetext=false&makeModelVariant3.searchInFreetext=false&minPrice=6000&maxPrice=7000&damageUnrepaired=ALSO_DAMAGE_UNREPAIRED&export=ALSO_EXPORT
http://suchen.mobile.de/auto-inserat/mazda-rx-8-revolution-wolfsburg/192365523.html?lang=en&pageNumber=11&__lp=61&scopeId=C&sortOption.sortBy=searchNetGrossPrice&makeModelVariant1.makeId=16800&makeModelVariant1.searchInFreetext=false&makeModelVariant2.searchInFreetext=false&makeModelVariant3.searchInFreetext=false&minPrice=6000&maxPrice=7000&damageUnrepaired=ALSO_DAMAGE_UNREPAIRED&export=ALSO_EXPORT
http://suchen.mobile.de/auto-inserat/infiniti-g35-2006-g35-coupe-3-5-hahnbach/192407784.html?lang=en&pageNumber=1&__lp=1&scopeId=C&sortOption.sortBy=searchNetGrossPrice&makeModelVariant1.makeId=11650&makeModelVariant1.modelId=3&makeModelVariant1.searchInFreetext=false&makeModelVariant2.searchInFreetext=false&makeModelVariant3.searchInFreetext=false&damageUnrepaired=ALSO_DAMAGE_UNREPAIRED&export=ALSO_EXPORT
Коя от колите в обявите да избера?
Re: Коя от колите в обявите да избера?
http://suchen.mobile.de/auto-inserat/bmw-330-mongrando/192633490.html?lang=en&pageNumber=2&__lp=2&scopeId=C&sortOption.sortBy=price.consumerGrossEuro&makeModelVariant1.makeId=3500&makeModelVariant1.modelId=15&makeModelVariant1.searchInFreetext=false&makeModelVariant2.searchInFreetext=false&makeModelVariant3.searchInFreetext=false&minFirstRegistrationDate=2005-01-01&minPrice=7&maxPrice=8000&negativeFeatures=EXPORT&minCubicCapacity=1800&maxCubicCapacity=3000
Добавям и този модел също при възможностите. Колата ще ми е първата, преди това съм карал други бързи коли, та това е от значение все пак. Разхода и подръжката също!
- Dagestan
- Регистриран на: Съб 30 ное 2013 19:04
- Автомобил: Toledo 1M2 и един Фокус
- Двигател: AGN 2000
- Местоположение: Разград
Тези Мазди винаги са ми харесвали много, но и винаги съм се чудел при някаква повреда или ремонт какво ще прави собственикът. В България надали има някой, който ги разбира тези ванкелови двигатели. Съмнявам се, че дори и в официален сервиз са запознати добре майсторите.
Не съм имал допир с нито един от посочените модели, но като гледам насоката бих избрал Инфинитито или Нисан 350Z.
- forski
- Регистриран на: Пет 07 мар 2008 22:10
- Автомобил: SUZUKI SX4 S-CROSS Boosterjet
- Местоположение: Сенник/Севлиево
По-добре пусни темата тук : http://forum.mazdabg.com/viewforum.php?f=42&sid=967acf38eb0b7cc7ab9e3f7de924522f
Във форума на VW колегите какво да ти кажат за RX8...
Човека гледа бързи/спортни коли и се чуди за данък и поддръжка
Да не говорим, че са по 200 коня и на горе + 6 цилиндрови
- stefan4o
- Автомобил: VW Jetta
- Двигател: PN 1990+KR 1987
Може и да бъркам, ама май имаше колега с такава във форума. Иначе да - едва ли някой тук може да е от полза за точно тоя модел кола.
- Mustang GT-R
- Регистриран на: Пон 04 апр 2005 23:13
И се регистрира във VW форума за да питаш за тези екзотични Мазди?
В наи общи линии..двигателя рядко изкарва повече от 130000-150000 без да се отвори за ремонт....разход градско около 14-15л изв града трудно под 10л.Има известен разход на масло около 5л на 12000км.Долива се двутактово масло във бензина.Задължително измерване на компресията която трябва да е над 8.5 бара при покупка...за ремонта.....ремонтира се естествено , само че в мазда сервиза няма да седнат да пробват каква компресия ще изкарат след ремонта и каква гаранция да дадат после и ако нещо не стане да им я връщаш по сто пъти. Ако си купуваш наи-добре на под 50000 км и пак проверка задължително. Иначе ако малко е паднала компресията най доброто е отваряне, смяна само на apex seals , пружинките им и gaskets рзбира се. В щатите това е около да кажем 500-600 долара. ако ти ги донесе някой няма да плащаш мито и транспорт. Варианта е приложим ако ротор хаузингите са с много леко износване. Печелиш от това че на 8 цата апексите са 4мм и при по-голямо износване бързичко охлабват в слотовете и ги прецакват , освен че на краен стадий може и да изскочат и да направят белята. При по-сериозно износване читавият вариант е само един: нови ротор хаузинги, ( около 500 долара единият а са 2) нов кит сегменти около 1200 долара и гарнитури около150-200 долара и лек шлайф на страничните хаузинги, това при условие че роторите ти не са със износени слотове. При всички други варианти забрави за прилична компресия.
Евентуално може да не сменяш маслените сегменти ако са с малко износване което е доста вероятно, а те са над 1/3 от цената на кита.
Такива ми ти работи....Уникална кола...уникална визия със тези задни врати...ама капризна.
