Колеги днес харесах един пасат 1.8Т 150к.с.
При диагностика ми излезнаха следните грешки, ако може някой да обясни какво знаат и струва ли си да се гледа този пасат 2004 година, цената е 6300лв.
VCDS Version: Beta 12.10.6
Data version: 20130531
Tuesday,09,September,2014,18:38:08:51315
Chassis Type: 3B - VW Passat B5
Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
VIN: WVWZZZ3BZ4E235751 Mileage: 128640km/79933miles
Address 01: Engine Labels: 06B-906-018-AWT.lbl
Part No: 4B0 906 018 DH
Component: 1.8L R4/5VT 0004
Coding: 11501
Shop #: WSC 05311
VCID: 6AD741AB157FE953BD7
WVWZZZ3BZ4E235751 VWZ7Z0C8695369
No fault code found.
Readiness: 0110 0001
Address 03: ABS Brakes Labels: 4B0-614-517.lbl
Part No: 4B0 614 517 G
Component: ABS/ESP front 3428
Coding: 04275
Shop #: WSC 05311
VCID: 254D7297BCE1062B505
1 Fault Found:
00526 - Brake Light Switch-F
36-00 - Open Circuit
Address 08: Auto HVAC Labels: 3Bx-907-044.lbl
Part No: 3B1 907 044 J
Component: CLIMATRONIC B5GP 0006
Coding: 17000
Shop #: WSC 05311
VCID: 28537BA3CBF31B436B3
1 Fault Found:
01299 - Diagnostic Interface for Data Bus (J533)
79-00 - Please Check Fault Codes
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 C
Component: 0E AIRBAG VW61 04 0003
Coding: 12357
Shop #: WSC 05311
VCID: 244B6F93B7DBFF2347B
Address 17: Instruments Labels: 3B0-920-xx5-17.lbl
Part No: 3B0 920 809
Component: KOMBI+WEGFAHRSP VDO V04
Coding: 05115
Shop #: WSC 00000
VCID: E1C5A68768492A0BECD
1 Fault Found:
01039 - Coolant Temperature Sensor (G2)
64-10 - Not Currently Testable - Intermittent
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 05311
VCID: F0E3D3C3B3A39383733
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 B
Component: 85 Komfortgerat HLO 0003
Coding: 00259
Shop #: WSC 05311
VCID: 366FA5DB11477DB3E9F
Subsystem 1 - Part No: 1C1959801
Component: 85 Torsteuer.FS KLO 0202
Subsystem 2 - Part No: 1C1959802
Component: 85 Torsteuer.BF KLO 0202
Subsystem 3 - Part No: 1C0959811
Component: 85 Torsteuer.HL KLO 0202
Subsystem 4 - Part No: 1C0959812
Component: 85 Torsteuer.HR KLO 0202
Address 56: Radio Labels: 1J0-035-18x-56.lbl
Part No: 1J0 035 186 E
Component: Radio BNO 0006
Coding: 05403
Shop #: WSC 05311
VCID: 2751789FC6ED143B629
End ---------------------------------------------------------------------
Грешки при Пасат Б5
- hi4umir4uu
- Регистриран на: Вто 23 юни 2009 13:28
- Автомобил: Passat b7
- Двигател: EcoFuel
- ti6ogb
- Регистриран на: Сря 21 апр 2010 20:54
- Автомобил: WV Passat Variant TDI 1.9
- Двигател: AVF - 2001
- Местоположение: Gabrovo
Re: Грешки при Пасат Б5
Колега,Пасата се води Б 5.5 (от 2001 до 2005) ,значи понеже карам дизел ,за бензина отзиви не давам.А за грешките,едната е за стоп машинка(или изгоряла стоп лампа ) ,другата е температурен датчик .И двете са по около 15 лв.и се сменят лесно. За другите не знам.
- mrpetrov
- Регистриран на: Чет 22 авг 2013 15:28
- Автомобил: 1997 Passat B5
- Двигател: 1.6 AHL
- Местоположение: ¯\_(ツ)_/¯
В лога се вижда, че и климатроника има някакво оплакване, ама програмата си те праща в прав текст - "Направи диагностика на климатроника."
- hooligans
- Модератор
- Регистриран на: Пет 30 мар 2007 19:22
- Автомобил: VW Polo Harlekin 1996
- Двигател: 1.6 AEE
Последно посещение: 12 Сеп 2014, 11:42
Потребители, разглеждащи този форум: amarinov и 53 госта
