Здравейте,
от скоро гледам Пасати и се насочих към два конкретни автомобила.
Проблема е, че единия е доста далеко от мен и се чудя, дали има смисъл да бия 400км. само за оглед.
автомобилът е Пасат 2004 1,9TDI 74Kw помпа-дюза, автоматик (предполагам 1N).
За съжаление не успях да открия много информация по VIN - номера, та ако има някой който може да помогне с повечко информация - моля!
При тест с VAG-kom нещата изглеждат по следния начин:
Saturday,11,October,2014,13:19:11:56599
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 14.7.2.0
Data version: 20140714
VIN: WVWZZZ3BZ4E066422 License Plate: PASSAT
Mileage: 139830km-86886mi Repair Order:
Chassis Type: 3B (3B - VW Passat B5 (1997 > 2005))
Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
VIN: WVWZZZ3BZ4E066422 Mileage: 139830km-86886miles
Address 01: Engine Labels: 038-906-019-AVB.lbl
Part No: 038 906 019 KC
Component: 1,9l R4 EDC G000AG 4896
Coding: 00001
Shop #: WSC 05314
VCID: 62C7298BED4FB113757-4B18
WVWZZZ3BZ4E066422 VWZ7Z0C7974827
3 Faults Found:
19586 - EGR System
P3130 - 35-10 - Regulation Range Exceeded - Intermittent
18027 - Glow Plug Relay (J52)
P1619 - 35-10 - Open or Short to Ground - Intermittent
18263 - Powertrain Data Bus
P1855 - 35-00 - Software Version Monitoring
Readiness: 1 1 0 0 0
Address 02: Auto Trans Labels: None
Part No: 01N 927 733 FD
Component: AG4 Getriebe 01N 5044
Coding: 00000
Shop #: WSC 00000
VCID: 78F36BE35BD34BC33B3-0962
1 Fault Found:
00529 - Engine Speed Signal Missing
35-10 - - - Intermittent
Address 08: Auto HVAC Labels: 3Bx-907-044.lbl
Part No: 3B1 907 044 K
Component: CLIMATRONIC B5GP 0010
Coding: 17000
Shop #: WSC 05311
VCID: 29557EA7D0F9224B74D-5178
2 Faults Found:
00603 - Footwell/defroster Flap Positioning Motor (V85)
01274 - Air Flow Flap Positioning Motor (V71)
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 A
Component: 7W Komfortgerбt HLO 0003
Coding: 00067
Shop #: WSC 05311
VCID: 356DA2D70C4176ABE05-4B32
Subsystem 1 - Part No: 1C1959801
Component: 7W Tхrsteuer.FS KLO 0202
Subsystem 2 - Part No: 1C1959802
Component: 7W Tхrsteuer.BF KLO 0202
1 Fault Found:
00912 - Window Regulator Switch; Front Left (E40)
27-10 - Implausible Signal - Intermittent
Address 56: Radio Labels: 1J0-035-15x-56.lbl
Part No: 1J0 035 152 E
Component: Radio GRO 0001
Coding: 00003
Shop #: WSC 05311
VCID: 20436383A3C3E303233-4B96
2 Faults Found:
00855 - Connection to CD changer
49-00 - No Communications
00856 - Radio Antenna
36-00 - Open Circuit
End-------------------------(Elapsed Time: 04:52)--------------------------
Моля за Вашето мнение, относно записаните грешки, има ли някои от тях, на които би трябвало да се обърне сериозно внимание?
Притесняват ме грешките, които записват двигателя и автоматичната кутия , по информация от човека, който я гледа, грешките се появяват и след изчистване и запалване.
Благодаря предварително!
Пасат 2004 1,9 TDI 74Kw помпа-дюза, автоматик, моля за мнение.
- Pet_rov
- Регистриран на: Сря 08 май 2013 16:16
- Автомобил: Passat Variant B4
- Двигател: ADZ 1996
- Местоположение: Шумен
Re: Ще купувам Пасат, моля за мнение.
Добро утро колега. Като за начало, объркал си раздела. Има подфорум "избор и покупка на автомобил.
Иначе, доколкото прочетох, имаш проблем с EGR клапана, реле някакво, липса на сигнал май за оборотомера(може и да бъркам) и моторчетата на клапите на климатроника, които са си цифра.
- Diters
- Регистриран на: Чет 05 апр 2007 8:31
- Автомобил: VW Passat variant
- Двигател: AVB
- Местоположение: на морето :)
Благодаря за бързия отговор,
извинявам се за грешката и моля ако има възможност, някой от модераторите да премести темата в правилния раздел.
Bro0z3r
- Регистриран на: Пон 11 юни 2012 16:39
- Автомобил: Passat B5
- Двигател: AFN 1997
Само че релето не е "някакво", а за подгревните свещи... Което, имайки предвид кой месец сме, не е за подценяване!
Клапите на климатроника са си цифра наистина! Но трябва да се погледнат, за да се прецени... А за да се погледнат, колата остава "по долни гащи"
Плюс това може да не работи шофьорското стъкло... Реве, че не вижда CD changer, което най-вероятно значи, че някой си го е взел за него си...
Виж дали хваща радио и как!
IRRITATING
- Регистриран на: Чет 29 ное 2012 15:32
- Двигател: AVF
Я кажи дали е типтроник или четиристепенен автомат защото ако е второто направо по добре търси друг
- Diters
- Двигател: AVB
Според информацията в нет-а
двигателя е с код AVB - 1,9TDi, 74kW, помпа -дюза
а кутията би трябвало да е 01N - 4-степенен автоматик.
Не открих никъде информация при този мотор да се монтира друга скоростна кутия с автоматични предавки.
- zoovanka
- Регистриран на: Чет 02 май 2013 13:10
- Автомобил: VW Caddy MAXI Life 1395 TGI 109
- Двигател: 2016 1395 TGI метан
колега какво значи тази грешка имам я и при мен,как се справи с проблема?
- hooligan_sk
- Двигател: EA113
Това е тема за избор на автомобил от 2014г, а не такава за решаване на изброените проблеми. Дори автора да го е закупил конкретно този автомобил и да се е борил с проблемите му в последствие, не е влизал във форума от половин година.
- zoovanka
Известни са ми правилата и моля да ме извините,но търся всякаква информация за проблемът ми.Намерих само в тази тема.
- hooligan_sk
- Двигател: EA113
http://www.vwaudiforum.co.uk/forum/show ... code-18263
Изглежда е спорадичен бъг който не заслужава внимание.
- zoovanka
Давах ток на жената/забравила фаровете/,преди седмица,четох че може да е свързано с грешката в чужди форуми,но да не спамя темата на колегата.
ВЕСЕЛИ ПРАЗНИЦИ !
ВЕСЕЛИ ПРАЗНИЦИ !
