Golf 5 1.6 BSE 102к.с. 2008г бензин/газ
deluxx21
Регистриран на: Чет 14 май 2020 22:18
Мнениеот deluxx21 » Пет 24 дек 2021 18:09
Здравейте! Днес си направих диагностика и това са резултатите! Какво е мнението Ви за диагностиката и какво следва да направя? Какви са проблемите, че не съм много на вътре с нещата? Благодаря предварително !!!!
Address 01: Engine Labels: 06A-906-033-BGU.lbl
Part No: 06A 906 033 GG
Component: SIMOS71 1.6l 2V 1025
Revision: --H04--- Serial number: VWX7Z0G93NG8YP
Coding: 0004071
Shop #: WSC 00028 028 00001
VCID: 6ADB77AF457FE0D9FC-803E
VINID: 9E69EAAAA05BA888001450430C21D4A441
3 Faults Found:
17549 - Load Calculation Cross Check
P1141 - 007 - Implausible Value - Intermittent
Freeze Frame:
Lambda: 49.6 %
Lambda: -35.2 %
Lambda: 34.8 %
T.B. Angle: 3.3°
Lambda: 49.6 %
Lambda: -35.2 %
Lambda: 34.8 %
T.B. Angle: 3.8°
18669 - Oxygen (Lambda) Sensor B1 S1
P2237 - 009 - Pump Current Open Circuit - Intermittent
Freeze Frame:
RPM: 1568 /min
Mass Air / Rev.: 87.2 mg/str
Voltage: 3.600 V
Bin. Bits: 00000100
16555 - Fuel Trim; Bank 1
P0171 - 006 - System Too Lean - Intermittent
Freeze Frame:
Lambda: 25.0 %
Lambda Factor: 1.101
Voltage: 0.040 V
Speed: 13.0 km/h
Lambda: 25.0 %
Lambda Factor: 0.992
Voltage: 0.140 V
Speed: 0.0 km/h
Readiness: 0010 1101
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0019073
VCID: 73E56ACB12B521114F-8026
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No SW: 1K0 820 047 FT HW: 1K0 820 047 FT
Component: Climatic PQ35 141 0909
Revision: 00141027 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 7BF542EB3AE5695117-802E
No fault code found.
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-M.lbl
Part No SW: 3C0 937 049 AH HW: 3C0 937 049 AH
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 01000005123385
Coding: 008D0F2700041500471400001400000000097B075C000100000000000000
VCID: 6FED66BB7E9D05F1AB-803A
Subsystem 1 - Part No: 1K1 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 171007 021 0501
Coding: 00038805
Shop #: WSC 00028
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: 37 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD1JPRVN
Coding: 0013111
VCID: 3D718CF36471A76169-8068
Subsystem 1 - Serial number: 6332MSME33505119+
Subsystem 2 - Serial number: 6342MSME33505A6DH
Subsystem 3 - Serial number: 6352QSME446C4C43Q
Subsystem 4 - Serial number: 6362QSME446B2E57V
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BB HW: 1K0 953 549 BB
Component: Lenksдulenmodul 636 0070
Coding: 0000002
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1K0 920 854 P HW: 1K0 920 854 P
Component: KOMBIINSTRUMENT VDD 1212
Revision: V0002000 Serial number: VWX7Z0G93NG8YP
Coding: 0003103
Shop #: WSC 12345 123 999999
VCID: 387F9DE74B538249BA-806C
Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533 Gateway H07 0052
Revision: H07 01 Serial number: 171007F2000801
Coding: E9807F060000020002
VCID: 306FA5C7A3235A09F2-8064
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 197
Reset counter: 255
Mileage: 206696 km
Time Indication: 0
Date: 2000.00.00
Time: 18:45:37
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VDD 1212
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb
Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
Component: Tuer-SG 006 1219
Coding: 0000180
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.068 H08 1901
VCID: 356194D35C417F21A1-8060
Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 809002005103087F2D04840560084F03E0FCA0
VCID: 03053A0B421511915F-8056
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
Coding: 0000180
VCID: 397998E370599B4145-806C
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
Part No SW: 1K0 959 703 K HW: 1K0 959 703 K
Component: Tuer-SG 006 1207
Coding: 0000144
Shop #: WSC 00028 028 1012545
Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb
Part No SW: 1K0 959 704 K HW: 1K0 959 704 K
Coding: 0000144
deluxx21
Re: Golf 5 1.6 BSE 102к.с. 2008г бензин/газ
Мнениеот deluxx21 » Съб 25 дек 2021 12:13
няма ли някой с мнение ??
tdi fen
Двигател: TDI AGR
Мнениеот tdi fen » Съб 25 дек 2021 12:33
бедна смес и вероятен проблем с ламбда сондата направи замерване на 32 33 канал на загрял двг без включени консуматори на бензин и на газ да се видят стойностите
deluxx21
Мнениеот deluxx21 » Съб 25 дек 2021 12:39
Благодаря tdi fen !! Очаквам и други мнения и за останалите проблеми
StS
Регистриран на: Нед 02 юли 2006 1:02
Автомобил: Golf VI
Мнениеот StS » Съб 25 дек 2021 12:41
Човека ти е писал вече, ако сондата ти е заминаваща, първо трябва да я смениш преди да се занимаеш с другите проблеми.
Потребители, разглеждащи този форум: ssssl и 97 госта
