Някой ако има предложение по какъв друг начин може да се активира освен чрез бутона, така че да светна led-a.
п.с в Биоас-а е enable, има си driver-и - device is working properly - да ама не
Vasseto написа:А изобщо има ли инсталирана карта такава,че някои модели имат копче и свето диод,но картата я няма и се очаква,че някога ще му бучнеш карта на MiniPCI и да ползваш тогава нет.
Wireless components: Wireless LAN/ Bluetooth
WBluiretleososthLAN
The installation of a wireless component not approved by Fujitsu Siemens
Computers GmbH voids the permits issued for this device (see "Technical data", Page 20).
Depending on the notebook model, wireless LAN and/or Bluetooth may be integrated in your
notebook. On delivery, WLAN components are switched on, Bluetooth components off.
Switching the radio components on and off
► Press the Easy Launch key for the radio components, to switch the radio components on or off.
WBUlMuireTtlSeososthLAN
or
► Press the Fn + F10 key combination to switch the radio components on or off.
The radio component indicator lights up when one or more radio components are switched on.
You can switch the wireless components on or off individually or together. For
information about the switch on/off sequence, see "Key combinations", Page 10.
If you switch the wireless components off, the Bluetooth module and the wireless
LAN transmission unit (antenna) are also switched off.
You can also deactivate the wireless components individually in the BIOS
Setup. To do this you must have at least a supervisor password. If the
wireless components have been switched off via the BIOS-Setup, they can no
longer be switched on with keys or key combinations.
Please observe the additional safety notes for devices with wireless
components provided in the "Safety" manual.
Details on using the wireless LAN are contained in the online help for your
wireless LAN software and in the "Wireless LAN" manual. The "Wireless LAN"
manual can be found on the "Drivers & Utilities" CD/DVD.
You can find more information on how to use Bluetooth on the CD you
received with your Bluetooth software.
Потребители, разглеждащи този форум: d00mEr и 65 госта
