Hella пуска LED DRL за Г5 от Януари 2008
brabus
R-циклопедист на VW
R-циклопедист на VW
Двигател: 1991 2003
Мнениеот brabus » Пет 30 ное 2007 10:33
Отговарят на всички спецификации и няма как да се заяждат полицаите, че това са халогени за мъгла.
The new vehicle-specific LED daytime running lights are type-approved (in accordance with ECE Directive 87) and will be available from specialist automotive aftermarket retailers from January 2008. The scope of supply includes corrosion-proof metal holders, plastic Design covers and a pre-assembled harness with perfectly sealed plug-connections and protectively-covered cable looms.
Hella has developed vehicle-specific LED daytime running lights for retrofitting to the Volkswagen Golf V and Ford Focus II. The fit perfectly into the front of the vehicle and look as if there were fitted as standard. Modern lighting technology and elegant design with a clear-glass look are combined to give a safety benefit while going easy on the environment: After all, two LED daytime running lights need just ten watts of power; additional consumption is not measurable.
The round lights are supplied with special covers that are tailor-made for the respective model. They fit exactly into the front apron and enhance the appearance of the vehicle. Three high-performance LEDs per light ensure a high level of recognizability during the day and therefore considerably improved safety in road traffic. They switch on automatically when the engine is started. The rest of the vehicle lighting is then not in operation. This eases the load on the energy balance. In addition, LEDs last for the life of a vehicle; their service life is about 10,000 hours of operation.
The LED daytime running lights consist of a robust, compact diecast aluminium housing. A shock-resistant plastic cover lens protects the light sources and the high-sheen metallized reflector. The lights are designed as a multi-voltage version and are therefore universally suitable for 12-volt and 24-volt vehicle electric systems. A relay integrated into the light saves an additional relay during installation.
Insect
Регистриран на: Съб 11 ное 2006 23:15
Мнениеот Insect » Пет 30 ное 2007 10:44
Тия хора се побъркаха вече... :screwy :bowdown :bowdown :bowdown :да: :да: :да:
4oroi4o
Регистриран на: Чет 16 фев 2006 9:19
Мнениеот 4oroi4o » Пет 30 ное 2007 10:46
bomber
Регистриран на: Вто 13 дек 2005 17:34
Местоположение: Софията
Мнениеот bomber » Пет 30 ное 2007 16:49
: vw fen
Gigabyte
Регистриран на: Нед 29 окт 2006 9:08
Автомобил: neko drugo
Двигател: vaprosche
Местоположение: Оряхово / Велико Търнуу
Мнениеот Gigabyte » Пет 30 ное 2007 17:11
:shock :shock :shock
Ще ги приспособим и за 2ката и за 1ците дори mhihi
: vw fen : vw fen
L&R
Автомобил: CCC
Мнениеот L&R » Пет 30 ное 2007 17:43
ретро седят обаче, ауди стайл е класи като визия над тези
longora
Регистриран на: Сря 15 мар 2006 12:18
Мнениеот longora » Пет 30 ное 2007 20:17
На други коли дали ще могат да се слагат ?
Vizor
Изгубена душа
Автомобил: Subaru Forester XT
Мнениеот Vizor » Пет 30 ное 2007 20:18
ЛиР .. тея ти изядоха хляба баце :lol:
golfer
Автомобил: Gandalf the Grey
Двигател: 368kw LPG
Местоположение: oberbayern
Мнениеот golfer » Пет 30 ное 2007 21:05
Vizor написа:ЛиР .. тея ти изядоха хляба баце :lol:
тц!
друг го изЕде !
KOKO ГЕОРГИЕВ
Мнениеот KOKO ГЕОРГИЕВ » Пет 30 ное 2007 21:32
С такава долнопробна като форма мрежа преди 20-40 години се ограждаха кокошарниците и зайчарниците. Абе на тия от VAG съвсем ли им изпушиха тиквите. :twisted: :roll:
