16500 engine coolant temp.sensor:implausible signal
16955 brake switch:implausible signal
Ако има колеги,които са се сблъсквали с подобен проблем моля помагайте!Благодаря
nikola1983 написа:Направих и диагностика и излязоха следните грешки:
16500/P0116/000278 - Engine Coolant Temp. Sensor (G62): Implausible Signal
Possible Symptoms
Starting the engine when engine is warmish or warm, idle rpm immediately is 1200 - 3000 rpm.
Diesel: an indication is extreme long time burning time of the glow indication light.
With all engine temperatures seldom idle rpm will vary between 900 - 1000 rpm.
With engine warm (90 °C) the engine temperature suddenly drops (70 °C) and slowly comes back to 90 °C.
Possible Causes
Wiring and/or connections faulty
Engine Coolant Sensor (G62) faulty
Possible Solutions
Check wiring and connections
Replace Engine Coolant Sensor (G62)
Потребители, разглеждащи този форум: televes и 56 госта
