Ще помоля за разяснение, какво трябва да се предприеме:
VCDS Version: Release 908.0
Address 01: Engine Labels: 058-907-55x-AEB2.lbl
Control Module Part Number: 8D0 907 558 B
Component and/or Version: 1,8L R4/5V MOTR HS D03
Software Coding: 04001
Work Shop Code: WSC 05314
3 Faults Found:
16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal
P0116 - 35-10 - - - Intermittent
17972 - Throttle Actuator (J338): Under-Voltage during Basic Setting
P1564 - 35-10 - - - Intermittent
17967 - Throttle Body (J338): Fault in basic settings
P1559 - 35-10 - - - Intermittent
Readiness: N/A
