Ето малко относно логване чрез RDC без парола:
How to Enable Remote Login via Blank Passwords using Local Security Policy or Group Policy Editor
The configuration to enable null (blank) passwords logon must be done on the host computer, i.e. the remote computer to remotely controlled. To configure the Remote Desktop host computer to accept user name with blank password, go to Control Panel -> Administrative Tools (Under System and Maintenance in Windows Vista) -> Local Security Policy. Alternatively, run GPEdit.msc (Group Policy Editor).
Then, expand Security Policies -> Local Securities -> Security Options (for user using Group Policy Editor or GPEdit.msc, expand Local Computer Policy -> Computer Configuration -> Windows Settings -> Security Settings -> Local Policies -> Security Options). Locate Accounts: Limit local account use of blank passwords to console logon only policy, and set its value to Disabled.
Това е през Group Policy, а следващото през registry-то:
How to Configure Blank Passwords Allowed for Remote Log On via Registry
Windows XP and Windows Vista stores the value of the policy set above in a registry key named “LimitBlankPasswordUse”. To unlock the limitation of cannot establish Remote Desktop logon with user account without a password, simply set the value data for LimitBlankPasswordUse to 0 (so that there is no limit on blank or null password use), as according to the code below. Alternatively, copy and paste the following text to a text file, and save with a .reg extension. Then run the .reg file to merge the value to registry.
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Lsa]
“LimitBlankPasswordUse”=dword:00000000
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Lsa]
Относно автоматичното логване:
цъкаш Start>Run пишеш control userpasswords2.
От прозорчето което излиза избираш юзера който искаш да се логва автоматично и махаш човката на "Users must enter a user name and passowrd ..." и си готов...
Това ще ти помогне...
Windows XP като орязан "гардеробен" сървър - Как ?
- wili98
- Щраусолог
- Регистриран на: Вто 07 дек 2004 12:42
1. Не разбрах за какво искаш да го ползваш този "сървар"
само СМБ + принтинг ли...
демек ще е файлов сървар + максимум принтване,
или щв му хвърляш някое дебело приложение да клати нещо..
или всичко в едно..
та по въпроса...:
аз лично бих сложил един виндоз 2000, или ХП...
има и windows XP медиа сервер /някъв едишън мисля че съм мяркал излез в последно време/
Виндоза работи перфектно.. като самостоятелна машина.. по-дуракоустойчив е от Х базирана система на гасене без шатдовн.
Вариант за гасене от бастър копче:
настройваш виндоза при натискане на бутона за гасене да се шатдоувнва..и после само трябва да си го пуснат.
Пускаш му WOL...
разрешаваш Терминал Сервисес...
и си в джаза..
shutdown има команда на всичко що е виндоз. и поддържа отдалечен рестарт и прочее...
стига с тези бози линдукс виндоз... работя в микрософтска среда.. е па да ви кажа честно,... личното ми ПЦ изкарва без гасене по 4-5 месеца и без рестарти.. не моам разбера ква е раз мълва...
ако ще го ползваш само за файлов сторадж..бих ти препоръчал да се поразтърсите за готови 200-300 лв NAS решения... относително бързи.. а и можеш да им накичулиш 100 кила софтуер.. /ма требе копане/ който да се цикли на тях..
удобни и готини.. и не пипаш много...
абе напиши за кво искаш да го ползваш... да посъветваме решение...
или всичко в едно..
та по въпроса...:
Пускаш му WOL...
и си в джаза..
- Tyan
- Ън Мън
- Регистриран на: Вто 14 дек 2004 21:31
[quote="Adnan"][/quote]
аз имам по 6000 закачени:) що не падат
...... изгражда се подходяща инфраструктура..лоад балансинг, отказоустойчовист,избира се ос....апликации дето ти вършат работа ..... или тръгваш в обратния ред ако е нужно....
Човек който ми твърди тази ОС е боклук, тази е страхотна ..просто според мен не е обективен в ИТ област като цяло .... ..за втори път го казвам това днес ..... това че при някой 2+2=4 не значи задължително че може да смята страхотно ..значи че може и просто да е налучкал
- musura
- Сър
- Регистриран на: Пон 28 мар 2005 21:01
- Местоположение: Голям Поровец
Мда, аз имам един сървър 2003 и на него вървят още 5 виртуални сървъври 2003
Спират, само ако аз ги рестартирам и ежедневно доста маймуни ползват сървърчетата... никакви грижи. Според мен, това е едно наистина много добро решение
Да не казвам, че имам приятел, който джурка един уеб сървър върху сървър 2003, на сървърна машина Дел, и този уеб сървър ъптайма му е до момента някъде към 2.5 години (демек не е спиран от как е пуснат, а се ъпдейтват сайтове редовно през ремуут десктоп)...
Та стабилността много зависи от самата машина - физически за какво иде реч като компоненти, после зависи и какъв софтуер ще върви върху ОС-а, какви антивирусни и т.н. подробности...
Някой от истинските специалисти може и да се смее, но преди около 5-6 години си бях организирал MS-DOS (за по-младите - това е съкращение от MicroSoft Disk Operating System) "файлов сървер" на един компютър с 486DX66 и четири диска. Нямаше монитор, клавиатура и мишка, само една мрежова платка която работи под ДОС. Затова нямаше проблеми и с рестартирането. На теб едва ли ти трябва нещо повече. И не струва нищо. А удоволетворението сам да направиш такова нещо е безценно
Описанието беше на Johannes Helmig но сега нещо не го намирам там.
Тук пише как се прави:
http://guam.packet.org:1104/J_HELMIG/dosclien.htm
http://guam.packet.org:1104/J_HELMIG/Dosservr.htm
Edit: Как да не се разплаче човек от умиление над тези думи:
A warning: these Microsoft DOS-network drivers are BIG, they take 100 Kbytes of the DOS-memory
- juve
- Регистриран на: Вто 07 мар 2006 22:43
- Автомобил: Pasat B3-Seat Leon TDI
- Двигател: AAZ - ALH
Добре колеги , мисля , че нещата ми се изясниха ....
Благодаря на всички отзовали се - по един или друг начин ми помогнахте да си реша проблема . Искам само да вметна, че целта на моето начинание беше максимум резултат с минимум усилия, защото както уточних , исках да реализирам нещо с наличната техника без допълнителни инвестиции и затова вариантите за преминаване , упгрейд на съществуващата щайга бяха неприемливи .... Относно Виндовс 2003 - сървър - със сигурност би било добре , обаче в моя случай става дума за не особенно натоварена система + липса на практически опит с 2003 сървър и особено пълното ми нежелание да отделя какъвто и да бил мозъчен ресурс за виндос .... важното е , че мисля достигнах благодарение на ВАС до задоволителен резултат и затова можете за заключвате темата .... А за лудия Патрик и неговата slackware и достойнствата на Виста може да си отворим тема в петък и хубаво да си почешем пръстите .......
