Windows XP като орязан "гардеробен" сървър - Как ?
bobi_robi
Регистриран на: Пон 17 мар 2008 18:14
Автомобил: Passat Б8
Двигател: DFHA 2021
Мнениеот bobi_robi » Вто 23 сеп 2008 16:10
Ето малко относно логване чрез RDC без парола:
How to Enable Remote Login via Blank Passwords using Local Security Policy or Group Policy Editor
The configuration to enable null (blank) passwords logon must be done on the host computer, i.e. the remote computer to remotely controlled. To configure the Remote Desktop host computer to accept user name with blank password, go to Control Panel -> Administrative Tools (Under System and Maintenance in Windows Vista) -> Local Security Policy. Alternatively, run GPEdit.msc (Group Policy Editor).
Then, expand Security Policies -> Local Securities -> Security Options (for user using Group Policy Editor or GPEdit.msc, expand Local Computer Policy -> Computer Configuration -> Windows Settings -> Security Settings -> Local Policies -> Security Options). Locate Accounts: Limit local account use of blank passwords to console logon only policy, and set its value to Disabled.
Това е през Group Policy, а следващото през registry-то:
How to Configure Blank Passwords Allowed for Remote Log On via Registry
Windows XP and Windows Vista stores the value of the policy set above in a registry key named “LimitBlankPasswordUse”. To unlock the limitation of cannot establish Remote Desktop logon with user account without a password, simply set the value data for LimitBlankPasswordUse to 0 (so that there is no limit on blank or null password use), as according to the code below. Alternatively, copy and paste the following text to a text file, and save with a .reg extension. Then run the .reg file to merge the value to registry.
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Lsa]
“LimitBlankPasswordUse”=dword:00000000
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Lsa]
Относно автоматичното логване:
цъкаш Start>Run пишеш control userpasswords2.
От прозорчето което излиза избираш юзера който искаш да се логва автоматично и махаш човката на "Users must enter a user name and passowrd ..." и си готов...
Това ще ти помогне...
wili98
Щраусолог
Мнениеот wili98 » Вто 23 сеп 2008 16:20
1. Не разбрах за какво искаш да го ползваш този "сървар"
само СМБ + принтинг ли...
демек ще е файлов сървар + максимум принтване,
или щв му хвърляш някое дебело приложение да клати нещо..
или всичко в едно..
та по въпроса...:
аз лично бих сложил един виндоз 2000, или ХП...
има и windows XP медиа сервер /някъв едишън мисля че съм мяркал излез в последно време/
Виндоза работи перфектно.. като самостоятелна машина.. по-дуракоустойчив е от Х базирана система на гасене без шатдовн.
Вариант за гасене от бастър копче:
настройваш виндоза при натискане на бутона за гасене да се шатдоувнва..и после само трябва да си го пуснат.
Пускаш му WOL...
разрешаваш Терминал Сервисес...
и си в джаза..
shutdown има команда на всичко що е виндоз. и поддържа отдалечен рестарт и прочее...
стига с тези бози линдукс виндоз... работя в микрософтска среда.. е па да ви кажа честно,... личното ми ПЦ изкарва без гасене по 4-5 месеца и без рестарти.. не моам разбера ква е раз мълва...
ако ще го ползваш само за файлов сторадж..бих ти препоръчал да се поразтърсите за готови 200-300 лв NAS решения... относително бързи.. а и можеш да им накичулиш 100 кила софтуер.. /ма требе копане/ който да се цикли на тях.. ;)
удобни и готини.. и не пипаш много...
абе напиши за кво искаш да го ползваш... да посъветваме решение...
Ivailo
Автомобил: VW Golf mk3
Двигател: AAZ
Местоположение: София/Видин
Мнениеот Ivailo » Вто 23 сеп 2008 17:03
wili98 написа:...абе напиши за кво искаш да го ползваш... да посъветваме решение...
Той написа, ние посъветвахме, а ти спеше :lol:
juve
Регистриран на: Вто 07 мар 2006 22:43
Автомобил: Pasat B3-Seat Leon TDI
Двигател: AAZ - ALH
Мнениеот juve » Вто 23 сеп 2008 19:10
мдааа верно написах , ама както винаги лееко се хванахме за гушата ллинуксари - фанатици ( като мене ) и Хората на Били и се оляхме .....иначе е написано няколко пъти , ама 4 страници преди ... :)
Tyan
Ън Мън
Регистриран на: Вто 14 дек 2004 21:31
Мнениеот Tyan » Вто 23 сеп 2008 19:25
[quote="Adnan"][/quote]
аз имам по 6000 закачени:) що не падат :)
...... изгражда се подходяща инфраструктура..лоад балансинг, отказоустойчовист,избира се ос....апликации дето ти вършат работа ..... или тръгваш в обратния ред ако е нужно....
Човек който ми твърди тази ОС е боклук, тази е страхотна ..просто според мен не е обективен в ИТ област като цяло .... ..за втори път го казвам това днес ..... това че при някой 2+2=4 не значи задължително че може да смята страхотно ..значи че може и просто да е налучкал :)
musura
Сър
Регистриран на: Пон 28 мар 2005 21:01
Местоположение: Голям Поровец
Мнениеот musura » Вто 23 сеп 2008 20:42
Мда, аз имам един сървър 2003 и на него вървят още 5 виртуални сървъври 2003 ;) Спират, само ако аз ги рестартирам и ежедневно доста маймуни ползват сървърчетата... никакви грижи. Според мен, това е едно наистина много добро решение ;)
Да не казвам, че имам приятел, който джурка един уеб сървър върху сървър 2003, на сървърна машина Дел, и този уеб сървър ъптайма му е до момента някъде към 2.5 години (демек не е спиран от как е пуснат, а се ъпдейтват сайтове редовно през ремуут десктоп)...
Та стабилността много зависи от самата машина - физически за какво иде реч като компоненти, после зависи и какъв софтуер ще върви върху ОС-а, какви антивирусни и т.н. подробности...
Tougi
Регистриран на: Пет 13 юли 2007 23:43
Мнениеот Tougi » Вто 23 сеп 2008 21:04
Някой от истинските специалисти може и да се смее, но преди около 5-6 години си бях организирал MS-DOS (за по-младите - това е съкращение от MicroSoft Disk Operating System) "файлов сървер" на един компютър с 486DX66 и четири диска. Нямаше монитор, клавиатура и мишка, само една мрежова платка която работи под ДОС. Затова нямаше проблеми и с рестартирането. На теб едва ли ти трябва нещо повече. И не струва нищо. А удоволетворението сам да направиш такова нещо е безценно :)
Описанието беше на Johannes Helmig но сега нещо не го намирам там.
Тук пише как се прави:
http://guam.packet.org:1104/J_HELMIG/dosclien.htm
http://guam.packet.org:1104/J_HELMIG/Dosservr.htm
Edit: Как да не се разплаче човек от умиление над тези думи:
A warning: these Microsoft DOS-network drivers are BIG, they take 100 Kbytes of the DOS-memory
dj_tuhla
Регистриран на: Съб 18 фев 2006 0:38
Местоположение: Голо Бърдо
Мнениеот dj_tuhla » Вто 23 сеп 2008 22:09
Абе до колкото помня XP Pro е резнато на 10 едновременни връзки към него макс, а XP Home на 2. Не знам къв сървър може да е това, еле пък за SMB.
Иначе бисери в темата не липсват...
А да, и да попитам само, единствения разработчик на Slackware не полудя ли миналата година :twisted:
juve
Двигател: AAZ - ALH
Мнениеот juve » Сря 24 сеп 2008 8:55
Добре колеги , мисля , че нещата ми се изясниха ....
Благодаря на всички отзовали се - по един или друг начин ми помогнахте да си реша проблема . Искам само да вметна, че целта на моето начинание беше максимум резултат с минимум усилия, защото както уточних , исках да реализирам нещо с наличната техника без допълнителни инвестиции и затова вариантите за преминаване , упгрейд на съществуващата щайга бяха неприемливи .... Относно Виндовс 2003 - сървър - със сигурност би било добре , обаче в моя случай става дума за не особенно натоварена система + липса на практически опит с 2003 сървър и особено пълното ми нежелание да отделя какъвто и да бил мозъчен ресурс за виндос .... важното е , че мисля достигнах благодарение на ВАС до задоволителен резултат и затова можете за заключвате темата .... А за лудия Патрик и неговата slackware и достойнствата на Виста може да си отворим тема в петък и хубаво да си почешем пръстите ....... :lol: :lol: 8)
Ivailo
Двигател: AAZ
Мнениеот Ivailo » Сря 24 сеп 2008 10:09
Бийте катанеца, че ще стане една...
