Покупка на VW Passat B8 от DasWeltAuto или автомобил от чужбина ?
VWGT
Re: Покупка на VW Passat B8 от DasWeltAuto или автомобил от чужбина ?
Мнениеот VWGT » Вто 27 май 2025 6:41
Най-лесно копи/пейст в chatgpt или друго подобно, и ще получиш подробно инфо (винаги с 1 на ум :)
Пример:
here’s a detailed explanation of the feature “VL3 Extended and Proactive Pedestrian Protection” specifically in the Volkswagen Passat B8.5 (2019 facelift version):
What is “VL3 Extended and Proactive Pedestrian Protection”?
This is a driver assistance and safety feature that’s part of Volkswagen’s Front Assist system, and it refers to a high-level (VL3) version of pedestrian protection. Let’s break it down:
✅ 1. “VL3”
• “VL3” stands for “Verbund Level 3” — this is Volkswagen internal terminology used to classify safety system versions.
• In this context, VL3 indicates the most advanced or fully-featured version of the pedestrian protection system available for the vehicle.
• It is not related to SAE Level 3 autonomous driving.
Think of VL1, VL2, VL3 as tiers or versions — VL3 being the most comprehensive.
✅ 2. “Proactive Pedestrian Protection”
This part of the system:
• Uses radar and a front-facing camera to detect pedestrians or cyclists in front of the car.
• If the system detects a likely collision:
• It warns the driver via sound and visuals.
• If the driver does not react, it will automatically apply the brakes to avoid or reduce impact.
• The system can respond faster than a human, and it’s always active at relevant speeds.
✅ 3. Why is it called “Extended”?
The “Extended” part means that this system is more advanced than the basic version and includes additional capabilities:
Basic System vs VL3 Extended System
Detects pedestrians mostly in daylight and low speeds
Works at higher speeds (up to ~70 km/h)
Limited detection area
Wider detection angles and better low-light performance
Basic camera and radar cooperation
Enhanced radar-camera fusion, better prediction of motion
Slower reaction
Faster intervention and braking performance
May not detect cyclists
Detects both pedestrians and cyclists
So, “Extended” means:
• The system covers more real-world scenarios (e.g., poor weather, dusk/dawn).
• It protects more vulnerable road users, with a wider range of detection.
• It’s better suited to urban driving, where sudden pedestrian crossings are common.
On the Passat B8.5
In the Passat B8.5, this system is part of the Front Assist package, and works through:
• A5 Control Module (camera and radar-based)
• Driver assistance systems menu (in infotainment)
• Optionally displayed in OBDeleven/VCDS as “VL3 Extended and Proactive Pedestrian Protection” when diagnosing or tweaking features
It’s always on by default, but some users see it listed or configurable in diagnostic tools.
✅ Summary (Simple Explanation)
In your Passat B8.5, “VL3 Extended and Proactive Pedestrian Protection” is an advanced safety system that:
• Detects people or cyclists in front of the car using radar and camera.
• Warns the driver of a possible collision.
• Automatically brakes if the driver doesn’t react in time.
• Works at higher speeds, in more complex situations, and with wider detection coverage than earlier or basic systems.
• “VL3” simply marks this as the most advanced version of this system in your vehicle.
Traytor
Автомобил: Passat B8
Двигател: DSRB
Мнениеот Traytor » Вто 27 май 2025 7:18
Както VWGT каза, chatgpt туке ти е приятел, за някои от екстрите ти давам обяснения от там, други ги имам и съм ти ги обяснил до колкото мога.
2R9 - ако има ел. реглаж на волана означава че седалката може сама да се отмества назад при отваряне на вратата и волана се вдига до най-високата позиция за по-лесно слизане/качване в колата.
4GF по-добра термо и акустична изолация(уж е по-тихо)
4I7 KeylessGO ти е паленето с бутон, Safelock не разрешава да се отвори вратата отвътре когато колата е заключена с дистанционното( тоест ако си заключиш колата, ако се счупи джама не могат да отворят с дръжката отвътре и трябва да влизат през него)
6K4 ACC high ти е регулиране на скоростта на база 2 фактора, знаци за ограчичение(отвратително в България, многократно опитах да го ползвам…) и терен(много остри завои, кръгови и прочие) общо взето използва картите от навигацията.
7UT
Navigation system “Discover Media” — with touchscreen, voice control, and map updates - имаш интегриран esim в колата и интернет връзка за да може мултимедията сама да си тегли ъпдейти и колата да праща информация до VW и от там ти вземаш малко информация за приложението на телефона, колата няма как да и се сложи дата план от наш оператор, работят само с кюбик телеком, ама цените не са много розови и се ползва само за wifi hotspot и аудио стрийминг, аз лично не се възползвах от тая опция.
7W2 затяга коланите и затваря прозорците преди сблъсък
8T8 работи до напълно спиране, ако си втора кола на светофара например, ще спре зад първата и ще цъкне аутохолда.
GM1 да
GP1 Най-вероятно софтуерен пач преди да излезе от завода
VL3 ако ще блъснеш пешеходец гръмват едно патрончета за да надигнат задната част на предния капак, така като пешеходеца си удари главата е малко вероятно огъването на капака да стигне до мотора(един вид си удря главата на меко и да мек ни е капака като ламарина)
YOS we connect ти е basic пакета който си остава включен на колата и осигурява интернет връзката за която говорих по-рано, we connect plus е годишен subscription който ти дава опцията да ъпдейтваш картите over the air, да включиш клаксона, аварийните и да отключиш колата през приложението. 289лв годишно за това си е безмислено.
WBH стандартен пакет който предлагат от VW:
Discover Media or Discover Pro Navigation
Integrated touchscreen navigation system with voice control, map updates, and connectivity functions
App-Connect
Includes Apple CarPlay, Android Auto, and MirrorLink (wireless in MIB3 systems)
Digital Cockpit
Fully digital instrument cluster with configurable display
Bluetooth Hands-Free System
Enhanced phone connectivity for calls and streaming
Multifunction Steering Wheel
With buttons for audio, voice control, and driver assistance systems
Front & Rear Parking Sensors
Often bundled with a rearview camera
Cruise Control (or ACC)
Standard cruise or Adaptive Cruise Control, depending on model
Extended Warranty / Service Pack
In some markets, this package also includes longer warranty or free servicing intervals for fleets
VWTouaregTDI
Регистриран на: Вто 24 фев 2015 19:32
Мнениеот VWTouaregTDI » Вто 27 май 2025 11:50
Супер. Много благодаря за полезната информация.
А предвид това, че колата няма да прави ъпдейти over the air какво се изисква от мен като ъпдейти и действия по навигацията и колата като цяло ?
Traytor
Двигател: DSRB
Мнениеот Traytor » Вто 27 май 2025 11:59
Колата винаги ще прави ОТА ъпдейти на компонентите по мултимедията като си с Discover media(мултимедия, радио и телефония ако не се лъжа), винаги ще иска потвърждение*.
За навигацията, наскоро линквах в друга тема, теглиш последните карти от VW, приготвяш си една 64gb флашка да имаш(32 стига, ама вече са евтини и така има потенциал ако се вдигне размера на картите), трябва да е или USB-C или да си купиш преходник от USB-A<>USB-C, форматираш я в NTFS и разархивираш картите в основната директория. После включваш флашката в USB-то пред скоростния лост и караш няколко дена. Ама в момента вече слагаш каруцата пред коня, купи колата и тогава мисли как да и ъпдейтваш картите, които повярвай ми няма да ползваш, освен ако не ходиш в Сърбия или Турция, защото Google(Waze) са в пъти по-точни и полезни.
VWTouaregTDI
Мнениеот VWTouaregTDI » Вто 27 май 2025 23:15
И това е така. Благодаря и надявам се скоро да има на какво да тествам.
Потребители, разглеждащи този форум: Google [Bot] и 49 госта
