import mx.core.UIObject;
intrinsic class mx.managers.DepthManager
public function DepthManager();
static var __depthManager:mx.managers.DepthManager;
public var _childCounter:Number;
public var _parent:MovieClip;
public var _topmost:Boolean;
public function buildDepthTable(Void):Array;
public function createChildAtDepth(linkageName:String, depthFlag:Number, initObj:Object):MovieClip;
public function createClassChildAtDepth(className:Function, depthFlag:Number, initObj:Object):mx.core.UIObject;
public var createClassObject:Function;
static function createClassObjectAtDepth(className:Object, depthSpace:Number, initObj:Object):mx.core.UIObject;
public var createObject:Function;
static function createObjectAtDepth(linkageName:String, depthSpace:Number, initObj:Object):MovieClip;
public function findNextAvailableDepth(targetDepth:Number, depthTable:Array, direction:String):Number;
public var getDepth:Function;
public function getDepthByFlag(depthFlag:Number, depthTable:Array):Number;
static var highestDepth:Number;
static private var holder:MovieClip;
static var kBottom:Number;
static var kCursor:Number;
static var kNotopmost:Number;
static var kTooltip:Number;
static var kTop:Number;
static var kTopmost:Number;
static var lowestDepth:Number;
static var numberOfAuthortimeLayers:Number;
static var reservedDepth:Number;
public function setDepthAbove(targetInstance:MovieClip):Void;
public function setDepthBelow(targetInstance:MovieClip):Void;
public function setDepthTo(depthFlag:Number):Void;
public function shuffleDepths(subject:MovieClip, targetDepth:Number, depthTable:Array, direction:String):Void;
static function sortFunction(a:MovieClip, b:MovieClip):Number;
public var swapDepths:Function;
static function test(depth:Number):Boolean;
File Recovery - HELP
- ACCELERATOR
- Регистриран на: Съб 23 окт 2004 19:00
- Местоположение: София - Враца
Абе спря ми тока, и ми се затри едно много важно PHP, по което съм работил цял ден... Изтеглих някакви програмки за възстановяване на файлове. И двете ми откриха файла, но като го отворя и излиза някакъв странен код. Явно е на някакъв език, но няма нищо общо с php... Някой може ли да помогне и да каже какво е това всъщност, и мога ли да си спася файла? (понеже програмирам и на флаш - та това ми прилича на ActionScript ?!?!)
- Vizor
- Изгубена душа
- Регистриран на: Съб 04 мар 2006 16:01
- Автомобил: Subaru Forester XT
Батенце утре ще питам приятел дето е бот на такива работи
иначе това е абсолютно същото като
https://engineering.purdue.edu/SafeWate ... anager.asi
- ACCELERATOR
Знам, но го намира точно в същата папка, където беше, и точно със същото име
Визоре, дано твоя приятел успее да помогне, пиши тук в темата, иначе май ще трябва пак да пиша наново
М/у другото, какво е това, което си пуснал? Верно като код същото изглежда, но... Чудно как се е озовало на мястото на моя файл?!
didoriginal
- Фотограф на VWClubFest
- Регистриран на: Нед 23 яну 2005 16:44
Преди време колега на баща ми имаше подобен на твоя проблем, но с "малката" разлика, че файла беше го писал и допълвал цяла година и нещо. "Специалистите" във службата му бяха казали, че изобщо няма шанс. Е, аз отидох и след 20 мин. имах файла, но от него се четяха само 2-3 sheet-a (Екселски беше). Лошото е, че той вече беше създал файл с такова име на мястото на стария. Сега ъплоуд-нах и пакета, който ползвах. Дано на теб ти свърши работа:
http://store1.data.bg/didoriginal/Apps/File%20Recovery/
- Stoi
- Вечен БАН
- Регистриран на: Пон 03 окт 2005 21:02
- Автомобил: Golf2EJettaMk2coupeZZR600
- Местоположение: Кричим
Това винаги ми е помагало
http://www.download.bg/index.php?cls=pr ... t&id=22032
разрови се из дата.бг за .......... версия
- ACCELERATOR
Пробвах 3 различни програми, и трите изкарват този код... Говорих с един пич, който ги разбира нещата, и той каза, че най-вероятно (понеже едва след няколко часа се усетих) някой сайт си е пляснал темпорари кода върху моя файл. Програмите го намират по име, отварят го, но... там вече има нещо друго. Благодаря все пак на всички!
Добре все пак, че файла беше само един, и ще го напиша за един ден, а не е нещо по-сериозно. Благодаря на всички, които се опитаха да помогнат!!!
didoriginal
ACCELERATOR написа:Пробвах 3 различни програми, и трите изкарват този код... Говорих с един пич, който ги разбира нещата, и той каза, че най-вероятно (понеже едва след няколко часа се усетих) някой сайт си е пляснал темпорари кода върху моя файл. Програмите го намират по име, отварят го, но... там вече има нещо друго. Благодаря все пак на всички!
Това ми беше и мисълта. Принципно при FAT32 системи по-лесно се recover-ват файлове, но при теб съм 99% сигурен, че е NTFS.
- mishu
- Регистриран на: Пет 27 май 2005 16:14
Щом като си се усетил късно, шансовете намаляват доста. Като се изтрие някой файл от харда той дефакто не се изтрива ами файловата система го брои за изтрит. Обаче ако изтриеш нещо и после пишеш пак по харда има голям шанс да пишеш върху това, което си изтрил. И така няма как да ти намери твоя файл. Ако се беше усетил веднага щеше да си го върнеш
Сега може да тестваш с раличните видове revival-ли ама щом една не го намира не вярвам някоя да го намери.
- ChampioN
- Регистриран на: Нед 17 сеп 2006 14:48
http://www.ericphelps.com/uncheck/
Затриха ми се от USB сумати важни не6та и на мен и с таzи програма успя да вастонови много от тях, но не вси4ки
Има ли някой идея zа друга програма, която вастановява такива CHK файлове напални, пЪк ако може и да им врЪ6та и името, 4е са над 700
