Колеги,някой може ли да ми помогне,като ми преведе ей тия неща,много ще съм благодарен
Предварително благодаря,ако темата не е за тук - триите я,пак се извинявам
JDeveloper is a free IDE from Oracle. It offers features for development in Java, XML, SQL and PL/SQL, HTML, JavaScript, BPEL and PHP. JDeveloper covers the full development lifecycle from design through coding, debugging, optimization and profiling to deploying.
With JDeveloper, Oracle has aimed to simplify application development by focusing on providing a visual and declarative approach to application development in addition to an advanced coding environment. In addition Oracle JDeveloper integrates with the Oracle Application Development Framework (Oracle ADF) - an end-to-end J2EE based framework that further simplifies application development.
Oracle JDeveloper is the main development platform for Oracle's tools. The core IDE exposes an API that other teams in Oracle use to build extensions to JDeveloper. BPEL, Portal, BI and other components of the Oracle platform all build their design time tool on top of JDeveloper. The same IDE platform also serves as the basis of another Oracle product, SQL Developer, which is geared specifically at PL/SQL and database developers.
Features
Prior to JDeveloper 11g, JDeveloper came in three editions: Java Edition, J2EE Edition, and Studio Edition. Each one offers more features on top of the others, and all of them are free. JDeveloper 11g only has two editions: Studio Edition and Java Edition. In 11g, J2EE Edition features are rolled into the Studio Edition.
A high level list of features includes:
Java Edition
• Java SE 5 Support
• Code Editor
• Code Navigation
• Refactoring
• Swing
• Unit Testing
• Version Control (however, branching is not supported by the internal CVS client)
• Audit & Metrics
• Debugging
• Profiling
• Ant Support
• XML Support
• Open API & Extensions
• User Assistance
J2EE Edition
• JSP
• Struts
• JSF
• EJB
• TopLink
• Web Services
• UML
• Database Development
• Deployment & Management
Studio Edition
• ADF Databinding
• ADF Faces
• ADF Mobile
• ADF Business Components
• ADF Swing
• ADF Deployment
• BPEL Designer
• ESB Designer
• Portlet Development
• Portlet/JSF Bridge
History
In 1998, the first version of JDeveloper was based on a licensing of the JBuilder product from Borland. JDeveloper went through a complete rewrite to be based on Java, for its 9i (2001) version.
The 10g version (9.0.5) showcased the first release of the revamped Oracle ADF.
In 2005, JDeveloper was released as free software.
In 2006, still under the 10g tag, and after significant delays, Oracle released version 10.1.3 - the latest major release.
In October 2006, Oracle released version 10.1.3.1 that added support for the final EJB 3.0 spec along with BPEL and ESB design time.
In January 2007, Oracle released version 10.1.3.2 that adds the Web Center capabilities such as creating and consuming portlets, portlet/JSF bridge, and content repository data control.
In January 2007, were more than 150 people working in various roles on the product comprising (in no particular order): developers, development managers, QA engineers, build engineers, doc writers, product managers, customer evangelists, and usability engineers. Development centers in Redwood Shores, Bangalore, Reading (UK), Pleasanton, Colorado. Source:[1]
In May 2007, a technology preview release of version 11g was released.
In October 2008, the production version of Oracle JDeveloper 11g, code named BOXER, became available.[2]
[edit] Visual and Declarative
The JDeveloper code editor offers a rich set of coding features and helpful utilities and visual utilities that provide a different view of the code as well as the declarative dialogs helping in creation of J2EE components.
For example JDeveloper provides a visual WYSIWYG editor for HTML, JSP, JSF, and Swing. The visual editor allows developers to modify the layout and properties of components visually and the code is changed for them. Any changes in the code will be immediately reflected in the visual view. Similar experience is provided for both JSF and Struts page flows.
Declarative features enable you for example to generate EJBs or POJO based on existing tables in databases. JDeveloper automates the creation of J2EE artifacts - for example with a simple click you can turn a java class into a Web Service and JDeveloper will generate the WSDL and all the required JAX-RPC components.
Oracle Forms
Oracle Forms is a tool (somewhat like Visual Basic in appearance, but the code inside is PL/SQL) which allows a developer to create user-interface applications which access an Oracle database in an efficient and tightly-coupled way. It was originally developed to run server-side in character mode on any Unix box, before MS Windows existed. It was then ported to Windows to function in a client-server environment. Recent versions have been ported to Java. It now runs in a J2EE container and can integrate with Java and web services.
The primary focus of Forms is to create data entry systems that access data in an Oracle database.
Product Position
Forms is part of the Oracle Developer Suite. This was at one time known as Developer 2000 or D2K and Oracle IDE Integrated Development Environment. Oracle marketed it as a Rapid Application Development tool.
How it works
Oracle Forms accesses the Oracle database and generates a default form that presents the data. The source form (*.fmb) is compiled into an "executable" (*.fmx), that is run (interpreted) by the forms runtime module. The form is used to view and edit data in business applications. Various GUI elements, such as buttons, menus, scrollbars, and graphics can be placed on the form.
The environment supplies built-in record creation, query, and update modes, each with its own default data manipulations. This minimizes the need to program common and tedious operations, such as creating dynamic SQL, sensing changed fields, and locking rows.
As is normal with event driven interfaces, the software implements a complex algorithm, consisting of special functions called triggers, which occur at critical steps in the processing of records, the receipt of keyboard strokes, and the receipt of mouse movements. Different triggers are called before, during, and after each critical step.
Each function is initially a stub, containing a default action or nothing. Programming Oracle Forms therefore generally consists of modifying the contents of these triggers in order to alter the default behavior. Some triggers, if provided by the programmer, replace the default action, others augment it.
As a result of this strategy, it is possible to create a number of default form layouts which possess complete database functionality yet contain no programmer-written code at all.
Превод от Английски език
- ABSOLUT
- Регистриран на: Пет 20 яну 2006 1:14
- Автомобил: Passat B4+B7+Golf Mk1+Mk2 Country
- Двигател: 1Z + CFGC + JB + 1P
Re: Превод от Английски език
Е ти нищо не помоли
Много е дълго за да се занимава някой да го превежда ред по ред.
Ако ти трябва колкото да хванеш смисъла на текста, пробвай с Google translate. Копи-пейст, изречение по изречение, и ще се ориентираш какво пише
- LILO&STICH
- ябълката на раздора
ха Пламене,виж кво ми преведе чичо ти
Цялото,ама колко е смислено
JDeveloper е безплатна IDE от Oracle. Той предлага възможности за развитие в Java, XML, SQL и PL / SQL, HTML, JavaScript, PHP и BPEL. JDeveloper обхваща цялостно развитие на жизнения цикъл от дизайн чрез кодиране, отстраняване на грешки, оптимизация и профилиране на разгръщане.
С JDeveloper, Oracle има за цел да опрости прилагането развитие, като се съсредоточи върху предоставянето на визуални и разказен подход към заявлението за развитие, в допълнение към съвременно кодиране на околната среда. В допълнение Oracle JDeveloper интегрира с Oracle Application Development рамка (Oracle ADF) - край до край J2EE базирани рамка, която улеснява прилагането нататъшно развитие.
Oracle JDeveloper е основната платформа за развитие на Oracle инструменти. Ядрото IDE излага една API, че други отбори в Oracle използват за изграждане на разширения на JDeveloper. BPEL, портал, BI и други компоненти на Oracle платформа всичките им градите дизайн време инструмент в началото на JDeveloper. Същото IDE платформа служи като основа на друг продукт, Oracle, SQL разработчици, която е насочена конкретно към PL / SQL бази данни и разработчици.
Характеристики
Преди JDeveloper 11 грама, JDeveloper дойде в три издания: Java Edition, J2EE Edition и Студио Edition. Всеки от тях предлага повече функции в горната част на другите, и всички от тях са безплатни. JDeveloper 11 грама, само има две издания: Studio Edition и Java Edition. В 11 грама, J2EE Edition функции валцувани в студио издание.
Високото ниво на списъка с характеристики включват:
Java Edition
• Java SE 5 Подкрепете
• Код на редактора
• Код Навигация
• Refactoring
• Swing
• Блок Тестване
• Версия контрол (все пак, разклоняване не е подкрепена от вътрешния CVS клиента)
• Одит & Метрика
• грешки
• профили
• Поддръжка на мравките
• XML поддръжка
• Отвори API & Разширения
• Съдействие за потребителя
J2EE Edition
• JSP
• Struts
• JSF
• EJB
• TopLink
• Web Services
• UML
• База данни за развитие на
• Deployment & Управление
Студио Edition
• ОДС Databinding
• ADF Лица
• ADF Мобилни
• ADF Бизнес Компоненти
• ADF Swing
• ADF Deployment
• BPEL дизайнер
• ESB дизайнер
• портлет развитие
• портлет / JSF мост
История
През 1998 г., първата версия на JDeveloper е основана на лицензиране на продукта от Borland JBuilder. JDeveloper премина през пълната стилизатор да бъдат базирани на Java, за неговото 9и (2001) версия.
В 10 грама версия (9.0.5) showcased първото съобщение на revamped Oracle ADF.
През 2005 г. JDeveloper е пусната като свободен софтуер.
През 2006 г., все още под 10 грама на етикет, и след значително забавяне, Oracle освобождава версия 10.1.3 - последната голяма съобщение.
През октомври 2006 г., Oracle освобождава версия 10.1.3.1, че добавя поддръжка на окончателното EJB 3,0 спецификационен заедно с BPEL и ESB дизайн време.
През януари 2007, Oracle освобождава версия 10.1.3.2 добавя, че в интернет център способности, като например създаване и потребление portlets, портлет / JSF мост, и съдържанието хранилище на данни контрол.
През януари 2007 г., са били повече от 150 души, работещи в различни роли на продукта, включваща (при не особено ред): програмисти, развитие мениджъри, QA инженери, изграждане инженери, докторе писатели, продуктови мениджъри, клиент пък благовестители, а използваемостта инженери. Развитие центрове в секвоя брегове, Бангалор, четене (Великобритания), Pleasanton, Колорадо. Източник: [1]
През май 2007 г., технологията за предварителен съобщение на версия 11 грама е била освободена.
През октомври 2008 г., производство версия на Oracle JDeveloper 11 грама, код име Боксер, станаха достъпни. [2]
[редактиране] визуална и разказен
В JDeveloper код редактор предлага богат набор от функции за кодиране и полезни помощни програми и визуални помощни програми, които предоставят различна гледна точка на кода, както и диалогови прозорци разказен помогне в създаването на J2EE компоненти.
Например JDeveloper осигурява визуална WYSIWYG редактор за HTML, JSP, JSF, и Swing. Визуалната редактор позволява на разработчиците да променят структурата и свойствата на компоненти, визуално и кодът се променя за тях. Всякакви промени в кода, ще бъдат незабавно отражение във визуален изглед. Подобен опит е предвидено и за двете JSF и Struts страница потоци.
Разказен характеристики ви позволяват например да генерира EJBs или POJO на базата на съществуващи таблици в бази данни. JDeveloper автоматизира създаването на J2EE предмети - например с обикновен клик, която може да превърне Java клас в уеб услугата и JDeveloper ще генерира WSDL и всички необходими Джакс-RPC компоненти.
Oracle Формуляри
Oracle форми е инструмент (известна като Visual Basic във външния вид, но вътре код е PL / SQL), която позволява на разработчика да създаде потребителски интерфейс, приложения, които Oracle база данни, достъп до по-ефективен и плътно-съчетано начин. Той първоначално е бил разработен за пускане на сървъра страна в характера на готовност по всички Unix кутия, преди MS Windows съществували. След това беше пренесли на Windows да работи по даден клиент-сървър среда. Последните версии са пренесли на Java. Той сега работи в J2EE контейнер и може да се интегрира с Java и уеб услуги.
Основният фокус на форми е да се създадат системи за въвеждане на данни, че достъп до данни в Oracle базата данни.
Продукт позиция
Формуляри е част от Oracle разработчици Suite. Това беше по едно и също време, известна като Разработчик 2000 или D2K Oracle IDE и интегрирано развитие на околната среда. Oracle на пазара като Rapid Application Development инструмент.
Как работи
Oracle Формуляри достъп на Oracle база данни и да генерира стандартна форма, която да представя данни. Източникът форма (*. fmb) се събира в "изпълним" (*. fmx), който се управлява (интерпретирани) от формите Runtime модул. Формулярът се използва за преглед и редактиране на данни в бизнес приложения. Различни GUI елементи, като копчета, менюта, scrollbars и графики могат да бъдат пуснати на формуляра.
Околната среда доставки застроена за рекордно създаването, заявка и актуализира видове, всеки със своите собствени подразбиране данни манипулации. Това минимизира нуждата от обща програма и досаден операции, като например създаването на динамични SQL, усещане промени полета, и блокиране редове.
Както е нормално със събитие задвижвани интерфейс, софтуерът изпълнява комплексен алгоритъм, който се състои от специални функции наречени води, които се проявяват при критични стъпки в обработката на данни, получаване на клавиатурата инсулти, както и получаването на движенията на мишката. Различни води се наричат преди, по време и след всяка критична стъпка.
Всяка функция е първоначално един пън, съдържащи по подразбиране за действие или нищо. Програмиране на Oracle Формуляри затова обикновено се състои от промяна на съдържанието на тези води, за да промени поведението по подразбиране. Някои води, ако е предвидено от програмист, сменете действие по подразбиране, други аугмент него.
В резултат на тази стратегия, е възможно да се създадат няколко подразбиране формата оформления, които притежават пълна база данни функционалност все още не съдържат програмист написана код на всички.
Характеристики
Java Edition
• Код на редактора
• Код Навигация
• Refactoring
• Swing
• Блок Тестване
• Одит & Метрика
• грешки
• профили
• XML поддръжка
J2EE Edition
• JSP
• Struts
• JSF
• EJB
• TopLink
• Web Services
• UML
Студио Edition
• ОДС Databinding
• ADF Лица
• ADF Мобилни
• ADF Swing
• ADF Deployment
• BPEL дизайнер
• ESB дизайнер
• портлет развитие
История
Oracle Формуляри
Продукт позиция
Как работи
- ABSOLUT
Е горе долу е добре.
Колегата ФВГ3 има достатъчно матриал да схване смисъла.
Разбира се с помоща на малко логическо мислене, 11g не е 11 грама
- Bob.Baev
- Регистриран на: Чет 23 фев 2006 18:15
- mladvampirTDI
- Регистриран на: Пет 11 мар 2005 11:12
- Местоположение: Sale, UK
Хахаха, превода става, поразбира се това онова, но един съвет към колегата vwg3 - Колега, ако не можеш да си го преведеш това, повярвай ми, информацията не ти е нужна по никакъв начин. Нищо лично, просто приложението на JDeveloper изисква познания по Английски до толкова, че да можеш да си преведеш readme-то.
- Adnan
- Регистриран на: Чет 08 фев 2007 14:36
mladvampirTDI написа: но един съвет към колегата vwg3 - Колега, ако не можеш да си го преведеш това, повярвай ми, информацията не ти е нужна по никакъв начин. Нищо лично, просто приложението на JDeveloper изисква познания по Английски до толкова, че да можеш да си преведеш readme-то.
или най малкото да може да си преведеш :
Код: Избери всички
declare @Account nvarchar(9)
set @Account = 'XXXXXXXXX'
select Case when IdReturn is null then 'Not returned' else 'Returned' end as Returned,
* from SentProducts with (nolock)
where IdSentDeliv in (select S.MultiLeaderId from SentDelivs S with (nolock) inner join Letters L with (nolock)
on S.App_Letter = L.Letter
where account = @Account
and L.CmbBilling = 1 )
послушай колегата горе има много право!
- Vizor
- Изгубена душа
- Регистриран на: Съб 04 мар 2006 16:01
- Автомобил: Subaru Forester XT
Аз си свикнах с Eclipse, но като гледам така.. по-добре си изтегли notepad++
- Supawiza
- Регистриран на: Съб 17 юни 2006 8:25
Ето го и моя превод
Develop Er е свободен Разнасят от оракула. То дава отличителни черти за развитие на ява, XML, SQL и PL /SQL , Html, JavaScript, BPEL и PHP. JDevelop Er покрива пълното Развитие lifecycle от създаването чрез кодирането, дебъгвайки оптимизация и описване при разгръщане. С JDevelop Er, оракъл е планирало да опрости развитие на приложение като фокусира при доставка зрително и декларативно идване до район на приложение допълнително към специализирана околна среда на кодиране. Допълнително Оракъл JDevelop er интегрира от приложението на Оракъл развитие на скеле (Оракъл ADF)- край, който ще --прекратява J 2 електроинженерство базира скеле, което опростява по - нататък развитие на приложение,. Оракъл JDevelop er е основната платформа за развитие защото оракъл е инструменти. Сърцевината отива Излага api за ан, което другите екипи като оракъл използват за да изградят разширения, на JDevelop Er. BPEL, Портал, бисмут и други компоненти на платформата на Оракъл, които всички изграждат, Тяхната цел настройва инструмент на връх на JDevelop Er. По същия начин Транспортирам Платформата служи също така като основата на друг продукт на Оракъл, разработчик от SQL, който е нагласен специфично за PL и / SQL и разработчици с база данни,. Симптом
Преди гигабайт на JDevelop Er 11, JDevelop Er дойде в три издания: издание в Java, издание с електроинженерство в J 2, и студийна издание. Всяка една дава повече отличителни черти на най - добри на другите, и всички тях са свободни. JDevelop Er на 11 гена има само две издания: студийна издание и издание на Ява. В 11 гена, J 2, които изданието към електроинженерство показва, са увити в студийната издание. Списък за високо ниво на отличителните черти включва:
Подкрепа на Se 5 Ява на издание на Java
Кодирайте навигацията за код на редактор
Промяна за Refactoring
Тествам единица контрол след версия (Както и да е, разклоняването не е поддържано от близките автобиографии от клиенти) Проверка и метрики
Описване на дебъгване
Мравката поддържа подкрепа на XML
Открийте api и съдействието на потребител по разширения
Издание с електроинженерство на J 2 JSP
Подпори JSF
EJB TopLink
Мрежа от Услуга UML
Разгръщане на развитие към база данни и управление
Студийно версия ADF Da tabinding
ADF гледа телефон на ADF
Бизнес ADF-компоненти Промяна на ADF
Дизайнер от BPEL от разгръщане ADF
ESB замисля развитие от Er Portlet
Portlet / история на JSF Bridge
За 1998, първата версия на JDevelop Er беше основана на лицензиране на продукта за JBuild Er от страната на бор. JDevelop Er мина A завършвам"преработи за да бъде базирана версия на Java, за неговите 9 аз (2001)". На версията на 10 гена (9. 0. 5) showcased първото издание на подновеното Оракъл ADF. В 2005, JDevelop Er беше освободен като свободен софтуер.
Като 2006, още под 10 гена обозначете, и след значителни забавяния, оракъл пусна версия 10. 1. 3 - последната значителна доставка. В октомври 2006, пусната версия за оракъл 10. 1. 3. 1, които прибавиха подкрепа за финалната спецификация за EJB 3. 0 заедно със BPEL и ESB, замислят времето. През януари 2007, оракъл пусна такава версия 10. 1. 3. 2, която прибавя способностите на център на мрежа, като създаването и консумирайки portlets, portlet на JSF Bridge, и доволно хранилище информацията контролира. През януари 2007, бяха повече от 150 човека, които работят за различни роли в състоенето на продукта (в никакво специално нареждане): разработчици, за които, мениджърите по развитие, инженер на QA, изграждам инженери, писатели на Док, продуктови мениджъри, евангелисти на клиент, и инженери с използваемост. Развитието се съсредоточава В Redwood от бряг, Bangalore, четене (великобритания), Pleasanton, колорадо. Източник: [1] за това, 2007, технология, може ли да прегледа изданието на версия на 11 гена беше пуснато. През октомври 2008, производственият превод на Оракъл JDevelop er на 11 гена, кодът на нареченият боксьор, стана наличен. [2] [edit] Зрителен и декларативен
Редакторът към код на JDevelop Er предлага на богаташ, който е поставен на кодиране, отличителни черти и полезни услуги и зрителни услуги, които предоставят различно становище на кода толкова добре, колкото декларативните диалози, които помагат със създаване на компоненти към електроинженерство J 2,. Например JDevelop Er предоставя зрителен wysiwyg редактор за html, JSP, JSF, и се клатушкайте. Зрителният редактор дава на разработчици да променят подредбата и свойства на компоненти визуално и кодът е променен с тях. Всички промени в кодекса ще бъдат веднага отразени в зрителния изглед. Подобният опит съм предвиден, че и JSF и подпорите номерират потоци. Декларативните отличителни черти ви позволяват за пример да създадете EJBs или POJO, които са базирани, от съществуващи маси в бази данни. JDevelop Er автоматизира създаването на артифактите към електроинженерство J 2- например с елементарен палец вие можете да обърнете клас от ява в уеб-услуга и JDevelop Er ще създаде WSDL и всичките необходими компоненти на JAX-RPC.
Формулярите за оракул на форми на Оракъл са инструмент (Доста харесайте visual basic при появяване, но кодът е вътре PL /SQL) Кой позволява на разработчик да създаде приложения на потребителски интерфейс, които достигат база данни в Оракъл, в ефективен и съединен здраво- начин . Беше оригинално развито да работят страните на сервитьор в характер на режим на коя да е кутия на Unix, преди прозорците на Мс да съществуват. То беше след това носено към прозорци за да функционира в околна среда на сървър на клиент. Скорошните версии са били носени на ява. То сега работи дo контейнер от J 2 електроинженерство и може да интегрира с ява и услуги на мрежа. Първостепенният център от формите ще създаде информация Системи от вход, които достигат информация в база данни за оракъл,. Продуктова позиция
Оформя това частта на разработчика от оракъл е ли свита. Това беше по едно време знайно, че като разработчик 2000 и Ds2 Ks и Оракъл отива към обединена околност на развитие. Оракъл го търгуваше като бърз инструмент в заявително развитие. Как работи
Формите в Оракъл достигат базата данни Оракъл и дават стандартна форма, която представя информацията,. Човешкото тяло на източник (* . Fmb ) Компилирано до"възможен" е (* . Fmx ) , Онова е защото бягането (преведе) от формите за способности на runtime. Формулярът е използван за да възприеме и редактира информация за работа на заявление. Различните GUIS-елементи, като например бутоните, менютата, scrollbars, и графиките могат да бъдат поставени във формата. Средата предоставя вградено създаване на репутация, запитайте и обновете режимите, всички манипулации със неговата собствена стандартна информация. Това минимизира нуждата за планиране, обичайна, и отегчителни действия, такива както създавайки динамичния SQL, усещането променя предмет, и заключването спори. Нормален точно толкова съм при събитие на мотивиран интерфейс, Софтуерът прилага сложен алгоритъм, Състоене от специални функции призова към причинител, което става при критични стъпки в преработването на резултатите, разписката, на ударите при клавиатура, и получаването на движенията от мишка. Различните причинители са призовани по - рано, During, И след като като всеки е критичен Стъпете. Всяка функция е първоначално никакъв остатък, подтискайки никакво действие на стойност по подразбиране или нищо. Програмиране на формуляри от оракъл затова предимно се състои от променяне на съдържанието на тези причинители за да промени стандартното поведение. Някои спусъци, ако е предоставеното от програмиста, заменят стандартното действие, друг го увеличавам. Като резултат за тази стратегия, е възможно, че създаване на много подредби за стандартна форма, които притежават функционалност към цялостна база данни досега, съдържа никакъв записан от програмист код за всичко.
Подпори JSF
EJB TopLink
Мрежа от Услуга UML
Колеги благодаря ви за подкрепата и смеха,за смях си е!
Просто аз си знам мога или не да го преведа,то няма смисъл да се говори ,щото трябва да започна с извиненията,кам пичовете който цъкат по-цял ден на pc-тата,щото един вид правейки се на луд ги карам а ми го преведат и подредят,следователно да ми свършат една тъпа и досадна работа
Мързелът и писането на още 4 курсови работи води до това ,да направя една простотия,карайки хората да ми свършат елементарната работа
Ще приема присмеха за себе си няма лошо и аз да бях щях да кажа същото
Поздрави и се извинявам на вс обидени
- ABSOLUT
Няма обидени бре
Потребители, разглеждащи този форум: Няма регистрирани потребители и 101 госта
