Съвет за грешки при диагностика с VAG-COM
RaVeN_
Регистриран на: Вто 15 апр 2008 19:28
Автомобил: VW Golf Plus
Двигател: 2000 TDI
Местоположение: Добрич
Мнениеот RaVeN_ » Съб 02 окт 2010 12:14
Колеги, моля за съвет какво означават тези грешки. Имам VW Bora 2.0i бензин/газ 1999 г.
VAG-COM Version: Release 409.1-S
Chassis Type: 1J - VW G/J/B Mk4
Scan: 01,02,03,08,16,15,17,19,22,35,46,56
Address 01: Engine
Controller: 06A 906 018 CT
Component: 2.0l R4/2V MOTR HS V05
Coding: 00000
Shop #: WSC 00001
11 Faults Found:
16806 - Main Catalyst: Bank 1: Efficiency Below Threshold
P0422 - 35-00 - -
17535 - Fuel Trim: Bank 1 (Mult): System too Rich
P1127 - 35-00 - -
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - - Intermittent
16685 - Cylinder 1 Misfire Detected
P0301 - 35-10 - - - Intermittent
16687 - Cylinder 3 Misfire Detected
P0303 - 35-10 - - - Intermittent
16688 - Cylinder 4 Misfire Detected
P0304 - 35-10 - - - Intermittent
16686 - Cylinder 2 Misfire Detected
P0302 - 35-10 - - - Intermittent
01115 - -
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes
Controller: 1J0 907 379 H
Component: ABS/EDS 20 IE CAN 0001
Coding: 13504
Shop #: WSC 01317
No fault code found.
Address 08: Auto HVAC
Controller: 3B1 907 044 B
Component: CLIMATRONIC S 0.3.2
Coding: 01000
Shop #: WSC 01317
2 Faults Found:
01206 - Signal for Duration of Ignition: OFF
Skipping Address 15-Airbags
Address 17: Instruments
Controller: 1J0 919 991 A
Component: A4-KOMBIINSTR. VDO V01
Coding: 22142
Shop #: WSC 74713
IMMO-IDENTNR: VWZ7Z0W0793344
Address 46: Central Conv.
Controller: 1J0 959 799 N
Component: 2K Zentral-SG Komf. 0002
Coding: 04097
Shop #: WSC 01317
5 Faults Found:
01483 - Control Circuit for Rear Lid Remote Unlocking
25-10 - Unknown Switch Condition - Intermittent
01332 - Door Control Module: Passenger Side (J387)
49-10 - No Communications - Intermittent
00943 - Heated Exterior Mirror: Driver Side (Z4)
00913 - Window Regulator Switch: Front Right Driver (E81)
27-10 - Implausible Signal - Intermittent
00944 - Heated Exterior Mirror: Passenger Side (Z5)
35-00 - -
Address 56: Radio
Controller: 3B0 035 186 C
Component: Radio 0003
Coding: 02405
Shop #: WSC 01317
End --------------------------------------------------------------------------------------------------
Sashko_Trg
Автомобил: Audi A4 Avant
Двигател: 2 0 TDI
Местоположение: Търговище
Re: Съвет за грешки при диагностика с VAG-COM
Мнениеот Sashko_Trg » Съб 02 окт 2010 12:19
Мале мале толкова грешли ли ти изкарва като я закачиш ??
pedalchobaba
Мнениеот pedalchobaba » Съб 02 окт 2010 12:24
Така като гледам повечето грешки са ти непостоянни. Временни. Като ги изтриеш появяват ли се пак?
Чети тук, какво пише за всяка една от тези, които ти останат.
okem
Регистриран на: Пон 15 юни 2009 19:59
Мнениеот okem » Съб 02 окт 2010 12:26
Здравей, колега ако за първи път и правиш диагностика не се ядосвай изтрий грешките карай я и пак и направи диагностика чак след това вземай мерки :wink:
RaVeN_
Двигател: 2000 TDI
Мнениеот RaVeN_ » Съб 02 окт 2010 15:34
Ще изтрия грешките и ще я тествам пак. И аз предполагам че повечто грешки са временни, единствено на двигателя - имам проблеми на бензин. И последно реших да ходя да ми почистят дюзите на ултразвук.
Мерси за линка за инфото!
