Може да е полезна на накои... Ще цитирам автора, на английски пише, но от самите снимки става ясно какво е направил и как, а ако има нужда ще го преведа по-късно.
greetings from NoPokemonShit - Finland
i got these damaged mercedes ATS barock wheels in 14" diameter and i was wondering what to do with them? they had been rendered useless because someone had driven them on the sidewalk and cracked the wheels.
So i took couple BBS RS 16" rimrings and got some crazy ideas
Then i thaught that why not to try to fit those lips on these wheels and i cut off the stock rimrings.
Then i drilled the holes in the remaining centerpiece, using a cracked rimring as a template.
after that it was normal splitrim assembly, ofcourse i needed to polish those old worn rimrings i had first. but everyone knows how to do that so i didn't bother to take any pictures.
almost the final product, i'm not sure what color i should paint'em. Mercedes astral silver is allways a good choice, the orginal color.
Ето и линк към оригиналната тема:
http://www.stanceworks.com/forums/showthread.php?t=8396
