Мнение за лаптоп Terra
- Vencitu
- Регистриран на: Вто 08 апр 2008 9:09
Здравейте колеги! Искам да попитам дали някой е имал допир до тази марка лаптопи и какво ви е впечатлението от тях,че ми предлагат един неизползван за що годе добра цена за параметрите му.Досега разбрах че се произвеждат от немска фирма и се водят business edition лаптопите им (поне това разбрах).Конкретния модел е Terra Mobile 1511
Характеристики:
Processor CPU AMD Athlon X2 Dual Core QL-62
(2.0GHz, FSB 667, 1MB L2 Cache )
Operating system: Original Windows ® 7 Home Premium 64-bit
Display 15.6 “WXGA (1366×768) Non Glare Screen, 16:9
Chipset AMD M780G
Memory 4 GB DDR2 RAM (2x 2GB modules), max. 4GB
Graphics VGA ATI Radeon HD3200 up to 512MB shared,
Hard Drive 500 GB S-ATA
Optical Drives DVD ± RW Dual Layer S-ATA
LAN LAN 10/100 RJ45,
Wireless LAN Wireless 802.11b/g/n
Webcam Integrated, 1.3 Megapixel
Express Card Slot no
Battery Li-Ion Battery 4400mAh (6 months warranty)
Power Supply 110/220V, 65 Watt
Interface: 3x USB 2.0,
1x RJ45 LAN, 1x VGA , 1x HDMI ,
1x microphone in, 1x headphone out,
9in1 Card Reader:
(MMC / RSMMC / SD / MiniSD / SDHC / SDXC / MS / MS Pro / MS Duo)
Kensington Lock
UMTS no
Bluetooth optional
Special Business keyboard with numeric keypad,
Anti-reflective display,
Silent Mode
Dimensions 374 x 250 x 14.3-34.1mm
Weight 2.4 kg
Software Kaspersky Internet Security OEM [DE] (90days Trial)
Microsoft Office 2010 * starter,
MS Windows Live services
Warranty 24 months Pick-Up-Return Service
Other 6 months warranty on battery
Battery life up to 4 1 / 2 hours maximum battery life
3 hours (Terra Rundown test)
(The actual duration depends on
Your hardware and software configuration.)
* * On this PC are limited
Versions of Word and Excel
pre-installed, contain advertising.
Purchase an Office 2010
Product key for Office Software
with full-featured
the PC to activate.
General product data
Manufacturer: Wortmann AG
Reference: 1220041
EAN-Code: 4039407014958
Gross Weight: 5kg
Net weight: 2.4 kg
Warranty: 24 month warranty including pickup TERRA MOBILE
Характеристики:
Chipset AMD M780G
9in1 Card Reader:
Kensington Lock
UMTS no
Bluetooth optional
Silent Mode
Weight 2.4 kg
with full-featured
the PC to activate.
Reference: 1220041
Gross Weight: 5kg
Net weight: 2.4 kg
- Haralampi
- Регистриран на: Пет 28 ное 2008 13:44
- Автомобил: VW Golf 4 - 2002
- Двигател: 1.6 16V - AZD
Re: Мнение за лаптоп Terra
Ако искаш качествена машина, която да не ти се счупи в ръцете за седмици/месеци и да ти прави постоянно проблеми, стой далеч от измишльотини като Terra, ако ще и да се води Astronautical серия!
Това са евтини китайски боклуци. Все едно да си вземеш реплика на телефон.
А че производителя се води немски.... е така
Но всъщност това е просто официалния търговец, който ги продава под свое име
Terra е от марките лаптопи, които се продават по хранителните магазини в Германия като Алди и Лидъл.
Купуват ги обикновено пенсионери, които се впечатляват от етикета с "екстри" и ниската цена
Ако непременно си решил да си купуваш лаптоп от хранителен магазин, нека бъде поне Medion
Но най-добре се ориентирай поне към Acer, макар че и тяхното качество е.... ама все пак зависи от модела - имат и сполучливи.
Аз се напатих достатъчно с измислени марки... вече знам, че евтино и качествено са 2 неща невъзможни в комбинация!
- stefan4o
- Автомобил: VW Jetta
- Двигател: PN 1990+KR 1987
И колко евтин е тоя лаптоп като цифра??
- Haralampi
stefan4o написа:И колко евтин е тоя лаптоп като цифра??
Ако е над 200 лв - е твърде скъп за това, което е. Отделно, че е доста неактуална конфигурация...
Някой ще ми обясни ли това технологично откритие.Цената наистина е най-главния фактор в тая задача.
- Golf`mafia
- Регистриран на: Чет 22 ное 2007 13:36
- Местоположение: Перник
Haralampi написа:stefan4o написа:И колко евтин е тоя лаптоп като цифра??
кое е толко неактуалното на конфигурацията двуядрен процесор, 4 гб рам, 500 хард,512 видео е,че на човек защо му е повече
- slimmer
- Регистриран на: Чет 24 апр 2008 7:36
- Автомобил: VW Bora
- Двигател: TDI-AJM 2002
Vencitu, по-добре недей. Братовчед ми понеже си взе някаква немска марка лаптоп преди време от Германия, сега не може да си намери чаркове за нея и си търси нов лаптоп...
Другото - тази конфигурация грее много, личен опит - старият ми лаптоп, купуван преди 3 години, беше със същите компоненти (което пък ти отговаря за актуалността на нещата вътре). Каквото и да е охлаждането (а то за евтин лаптоп съвсем няма да е добро), пак си грее много и не е сигурно колко ще изкара така. Ако търсиш нещо евтино си намери втора ръка Core 2 Duo - по-добро е със сигурност! И то по-марково, за да си нямаш проблеми после с поддръжката, ако се налага.
- Haralampi
Golf`mafia написа:Haralampi написа:stefan4o написа:И колко евтин е тоя лаптоп като цифра??
Двуядрен... ама какъв
Конфигурацията е като цяло от преди 3-4 години.
Бегай си далече,ама много далече
Има доста качествени нискобюджетни лаптопеци на добра цена,няма смисъл да си хвърляш парите за това чудо
- Vencitu
Благодаря за отговорите колеги! Ще откажа офертата след като прочетох толкова негативни мнения за лаптопа
- Haralampi
Vencitu написа:Благодаря за отговорите колеги! Ще откажа офертата след като прочетох толкова негативни мнения за лаптопа![]()
Най-евтината марка, която въобще заслужава някакво внимание е Acer. Почни от нея и върви нагоре до където ти стигат възможностите...
- radi_nrj
- Двигател: AEL ALH
Vencitu написа:Bluetooth optional
Е на това паднах от смях
- ChimeyJimmey
- Регистриран на: Съб 01 окт 2005 8:47
- Автомобил: торанага
- Двигател: AXQ
Haralampi написа:Vencitu написа:Благодаря за отговорите колеги! Ще откажа офертата след като прочетох толкова негативни мнения за лаптопа![]()
ACER май от години не спада към евтините марки...
Виж, Азис и производните му като Асрок - може.
- Haralampi
ChimeyJimmey написа:Haralampi написа:Vencitu написа:Благодаря за отговорите колеги! Ще откажа офертата след като прочетох толкова негативни мнения за лаптопа![]()
ACER май от години не спада към евтините марки...![]()
Acer от години не спада към "кучите марки"
Единствената "марка", която ми идва на ум и е по-зле от Acer, е Fujitsu(-Siemens). Пълни боклуци!! Далече от тях!
На 4-та марка лаптоп съм тъй като бая се напатих - почнах от "всеизвестната" IPC (Именно от класата на Terra
- Matematiks
- Регистриран на: Вто 27 ное 2007 17:29
Аз пак да кажа
За седмица си купувам втори лап наистина от БИЗНЕС серия на ИБМ и построен като такъв,не само по име а и по качество!
Лаптопа е 2006 година и цената му е смешна.Процесора е точно на 2,0 Гхц но не е АМД и не е на 667 а на 800 и не е с 2 кеш а със 4
(2006г)
Рамта е същата а видеото е интелско с 256 мега
Батерията нова е към 18 паунда Саньо и държи около 5 часа на фул сетингс
Ква Тера кво Чйело
Само екрана малко куца,но няма пълно щастие,пък и за 200 долара става с 1440/1050 на 12,1 инча
Аз лично стигнах до извода,че при липса на левове е по добре да се ъпгрейдне нещо истинско отколкото да се купуват евтини боклуци
(2006г)Рамта е същата а видеото е интелско с 256 мега
Ква Тера кво Чйело
