1.8 Т 20V в Голф 3 (или болната тема на някои хора)
opipva4a
Палячо
Регистриран на: Сря 09 юни 2004 9:04
Мнениеот opipva4a » Вто 01 фев 2005 18:12
ууууууфффффф
opipva4a
Палячо
Мнениеот opipva4a » Вто 01 фев 2005 18:19
малииииии........ как чакам момента
opipva4a
Палячо
Мнениеот opipva4a » Вто 01 фев 2005 18:21
само 3 (три) !!! Де и при мен да са така
I drove it to work today, and there are three important problems...well, four once I checked the codes.
1. pressure drop between turbo and throttle.
I think the boost leak is right at the MAP sensor, since I wasn't too keen on the fitting there anyway. I'll be checking the DV and N75 as well, but I'm pretty sure it's the MAP fitting. All the pipes are still connected. Anyway, T-bolt clamps are in the mail.
2. The rear ABS rotors aren't spinning with the brake rotors. I kinda thought this would happen, as I didn't purchase replacements for the old rusty ones. So the ASR/EDL kicks in at takeoff, and the whole ABS/ASR/EDL system shuts down once I get above 10mph. The quick fix is to disable ASR with the dash button every time I start the car. The longer fix is to disable ABS/ASR/EDL with the VAG-Com (I didn't have the codes on me). The actual fix I'm gonna make is to replace the rear ABS rotors with new units and ensure they are spinning right. I'll want that ABS working fully.
3. There's a coolant leak. The lower radiator hose was cut too short, and is not tight enough on the feed to the motor, so there is a semi-slow leak.
4. MAF sensor is throwing a code, readings too high ersumthin. Not sure if that's because of the CAI or something more serious. I know I didn't install it backwards, I was careful of that.
For now, I have no choice but to drive it slow, cause there ain't much boost. Speaking of which, I think my boost gauge should come in today...if it doesn't, i'm not gonna be happy.
opipva4a
Палячо
Мнениеот opipva4a » Вто 01 фев 2005 18:24
Ще му дойде акъла на тоя ....
opipva4a
Палячо
Мнениеот opipva4a » Вто 01 фев 2005 18:29
аре нямаше нужда....
ти се оия (боби прощавай)
изморен и ......... размислил за "маската"
а вътре.... нямам думи....
http://homepage.mac.com/theoptimist/carpix/interior/
Последна промяна от opipva4a на Сря 02 фев 2005 9:23, променено общо 1 път.
prj57
Регистриран на: Вто 08 юни 2004 12:04
Местоположение: София, Лондон
Мнениеот prj57 » Вто 01 фев 2005 20:41
Абе, на вас трябва да ви се забрани да тормозите хората с такива неща..... :lol:
prj57
Мнениеот prj57 » Вто 01 фев 2005 21:25
Тоя пич е случил на идеалния автомобил да ползва за донор.... в БГ такова нещо за тея пари на дали..... както и да го гледаш много от нещата са копъвани оригинално..... като гледам цените направо смешни като се сетя в Унито колко искат за резервни ВАГ части направо настръхвам......
Както и да е opipva4a има стартовия материал дано до лятото да си го сзглобил..... че да видим.... :lol:
Vladko
Регистриран на: Вто 07 дек 2004 16:44
Мнениеот Vladko » Вто 01 фев 2005 21:35
Вярно е това че не пали без таблото но като стигнете точно до там има човек който ще направи емулатор това да ви е проблема :D и на пролет Drive
opipva4a
Палячо
Мнениеот opipva4a » Сря 02 фев 2005 9:19
хмммммм
Независимо от това ще търся табло
брабусе. брабусе, няма покой вече
opipva4a
Палячо
Мнениеот opipva4a » Сря 02 фев 2005 10:33
ИМПЕРИЯТА ОТВРЪЩА НА УДАРА....
брабусе, тоя е над нещата
http://forums.vwvortex.com/zerothread?id=808137
като се запалиш ще те видя аз тебе
brabus
R-циклопедист на VW
R-циклопедист на VW
Двигател: 1991 2003
Мнениеот brabus » Сря 02 фев 2005 10:44
Ооооооооо не моеш да ме изненадаш :lol: мене жокер ми не требе, аз тоз го знам още от първото ми влизане в този сайт (от тогава ги уважавам).
Само понякога ме дразнят като кажат имам едно ново проектче и съм заделил 25 000 $ :banghead: :banghead: :banghead: bowdown bowdown bowdown
Vladko
Мнениеот Vladko » Сря 02 фев 2005 23:15
Любопитно ми е колко ли ще ми излезе същата операция в BG ако е нормална сума бих се замислил :D а дали ще стане VR6 turbo в Golf 1 Cabrio мисля че бях виждал такова нещо в нета но не мога да го намеря сега ако някой го види да свирне :D
opipva4a
Палячо
Мнениеот opipva4a » Чет 03 фев 2005 14:26
голфър-а даде вече тема за размисъл (благодарско)
почвам да уча полски
http://vwgolf.pl/porady/zegarymk4/
Потребители, разглеждащи този форум: amnesty, Google [Bot] и 55 госта
