Някой знае ли къде има опис на релетата на VW и тяхната номерация?
Пример:
19 - реле за чистачки
Списък с номерата на релетата на VW ?
- nasko1978
- Регистриран на: Сря 25 юли 2007 9:47
- Местоположение: Nürnberg ,Перник
Re: Списък с номерата на релетата на VW ?
Това е за Г4 !Дано да ти свърши работа.http://uk-mkivs.net/forums/t/168839.aspx
- Gigabyte
- Регистриран на: Нед 29 окт 2006 9:08
- Автомобил: neko drugo
- Двигател: vaprosche
- Местоположение: Оряхово / Велико Търнуу
1 = carb inlet manifold heater
2 = fuel pump (MK1 & Early MK2/Rocco K-Jet, no rev limiter)
5 = shift light and MPG gauge
18 = x-over relief (disables most ign live items while engine turning on starter motor)
19 = front wiper intermittant
20 = rear wiper non-intermittant (when you push the stalk forward, it'll only wipe once, no intermittant!)
21 = hazard/indicator
23 = switched relay, often used for electric windows
30 = MK3 (GTI 8v or 16v?) ECU
31 = 'time control unit' fan control
32 = MK2 digifant ECU
33 = headlight washers
36 = headlights on warning (possibly seatbelt too?)
42 = coolant level sensor control (pre-90 & digifiz dash)
43 = coolant level sensor control (pre-90 & digifiz dash)
53 = misc equipment ignition switched (horn, fogs, leccy windows etc)
62 = fuel pump (Later MK2/Rocco/Cabby K-Jet, built in rev limiter)
67 = MK2 16v/ MK3 VR6 fuel pump
72 = rear wiper intermittant
80 = MK2 digifant fuel pump
99 = front wiper variable intermittant
103= glow plug
104= glow plug
109= ACV engine code ECU?
133= aircon
150= starter motor
167= MK3 & MK2 16v fuel pump
174= rear wiper
191= hazard/indicator
192= intermittant wash/wipe for models w/rain sensor
204= 40a, fog lamp, electric fan etc. pinout compatible to 53
213= fan, assume radiator?
370= fan, assume radiator?
372= fuel pump relay, 97-05 Passat
389= intermittant wash/wipe
407= rear petrol flap
409= fuel pump relay, 02 Golf
за mk1 и mk2
- ceci4
- Регистриран на: Сря 25 май 2005 20:09
- Автомобил: VW Golf V TDI 16V
- Двигател: BKD 2004
- Местоположение: Плевен
Благодаря на всички за помощта, но това последното си беше точно попадение
- predat0r
- Регистриран на: Чет 02 фев 2012 13:44
- Автомобил: Mercedes-Benz W203
- Двигател: C270CDI
- Местоположение: АСЕНОВГРАД
Реле 22 - мигачи/аварийни Днеска го разбрах
- znainainai
- Автомобил: Golf4
- Двигател: MK 4 98 AHF
predat0r написа:Реле 22 - мигачи/аварийни Днеска го разбрах
Да ама за автомобили със ОЕМ Теглич
