Б4 комби - питане за обема на резервоара
Jovany
Регистриран на: Вто 19 юли 2005 18:37
Re: Б4 комби - питане за обема на резервоара
Мнениеот Jovany » Нед 25 ное 2012 19:04
А стига бе :shock
Сигурен ли си че не са те изментили :mrgreen:
krasio74
Регистриран на: Сря 05 сеп 2007 22:11
Мнениеот krasio74 » Нед 16 дек 2012 0:06
1993 facelift (Passat B4)
Main article: Volkswagen Passat (B4)
Volkswagen Passat Variant (Version B4)
The B3 Passat was heavily facelifted in 1993 and although it was designated B4, it was not an all-new model. The facelift revised external body panels except for the roof and glasshouse, with most obvious exterior change seeing the re-introduction of a grille to match the style of the other same-generation Volkswagen models of the era, such as the Mk3 Golf and Jetta. The interior was mildly updated and included safety equipment such as dual front airbags and seat belt pre-tensioners, although the basic dashboard design remained unchanged.
The car was available with a Turbocharged Direct Injection (TDI) diesel engine - an inline four-cylinder 1.9 litre turbodiesel, generating 210 newton metres (155 lbf·ft) of torque at 1,900 rpm, 66 kilowatts (90 PS; 89 bhp) at 3,750 rpm. It carried a U.S. EPA fuel efficiency rating for the sedan of 45 miles per US gallon (5.2 L/100 km; 54 mpg-imp) highway. Combined with a 98 litres (21.6 imp gal; 25.9 US gal) -28 litres (6.2 imp gal; 7.4 US gal) reserve option fuel tank, the B4 TDI wagon had a 1800+ km (1200+ mi) range on a single tank of fuel. The B4 TDI wagon saw less than 1,000 sales in the U.S. during its 1996 to 1997 lifespan.
аз карам комби 1Z и наистина събира около 90-100литра scare и аз не вярвах но вече 2 пъти съм го пълнил :D
поздрави и дано съм бил полезен
sonaris
Регистриран на: Съб 06 фев 2010 19:56
Автомобил: VW Passat B4 Syncro
Двигател: ADY
Местоположение: Пловдив / България
Мнениеот sonaris » Сря 02 яну 2013 1:55
Хубава тема. Само дето някой поглеждал ли е че човека е от Пловдив. Аз с бутилката газ на място на резервната гума ще ида до Кешан, Одрин, Турция. Все пак говорим за около 300км. Не е добре да се пълни толкова резервоара особено в топло време. Има си линейно разширение мисля че за това е оставено толкова много празно. Но все пак всеки си решава сам. Пък и винаги човека може да си инсталира газова. Така може още повече път да минава пък и по евтино. Ремъците с които резервоара е закрепен към купето обикновено са изгнили. Препълването е причина за скъсването им. 100 литра не знам колко килограма са но едва ли са по малко от 80. При разход от 10/100 са си 700км тези 70 литра. Но на този път и извън градското най вероятно няма да е този разхода ако МПС-то е изправно.
