Привет колеги, преди около месец при палене на колата оборотите започнаха да играят, но след 10-секунди се оправиха и се появи едно предърпване в 3-та скорост от време на време, което зачести и днес след като колата се захълца толкова, че едвам изкарах кръстовището и спрях... лампата за ESP и ABS светнаха, загасих-запалих и проблема изчезна... закачихме колата на компютър и показа това:
VCDS-Lite Version: Release 1.0
Monday, 09 December 2013, 12:55:24:0
Chassis Type: 3B - VW Passat B5
Scan: 01,02,03,08,15,16,17,19,35,36,37,46,47,55,56,57,58,75,76,77
Address 01: Engine Labels: 038-906-019-AVF.LBL
Controller: 038 906 019 DS
Component: 1,9l R4 EDC G000AG 1348
Coding: 00001
Shop #: WSC 05314
WVWZZZ3BZ1E227880 VWZ7Z0A3516978
1 Fault Found:
18075 - PD Unit Injector; Cylinder 2 (N241): Electrical Malfunction
P1667 - 35-00 - -
Readiness: N/A
Address 02: Auto Trans Labels: 01V-927-156.LBL
Controller: 3B0 927 156 S
Component: AG5 01V 1.9l-PD RdW 1416
Coding: 00103
Shop #: WSC 05311
3 Faults Found:
17125 - Torque Converter Clutch: Stuck OFF / No Power being transferred
P0741 - 35-00 - -
17117 - Gear 3: Incorrect Ratio
P0733 - 35-10 - - - Intermittent
18265 - Load Signal: Error Message from ECU
P1857 - 35-10 - - - Intermittent
Address 03: ABS Brakes Labels: 8D0-907-389.LBL
Controller: 8D0 907 389 D
Component: ABS/ESP front D56
Coding: 04257
Shop #: WSC 05311
1 Fault Found:
Address 08: Auto HVAC Labels: 3Bx-907-044.LBL
Controller: 3B1 907 044 H
Component: CLIMATRONIC B5GP 0003
Coding: 17000
Shop #: WSC 05311
1 Fault Found:
01273 - Fresh Air Blower (V2)
Address 46: Central Conv. Labels: 1C0-959-799.LBL
Controller: 1C0 959 799 B
Component: 0J Komfortgerat HLO 0002
Coding: 00259
Shop #: WSC 05311
4 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
37-00 - Faulty
00913 - Window Regulator Switch; Front Right Driver (E81)
27-10 - Implausible Signal - Intermittent
00930 - Locking Module for Central Locking; Rear Left (F222)
27-00 - Implausible Signal
00931 - Locking Module for Central Locking; Rear Right (F223)
End --------------------------------------------------------------------------------------------------
Моля ако някой е имал подобен проблем да пише.... четох по форуми където пише, че проблема се дължал на намален дебит на помпата в резервоара или на горивния филтър..., но ме съмнява.
Последно уточнявам, че проблема се получава когато си посика и зачести в последния месец.
Пасат 3B 1,9ТDI 2001 няколко проблема?
- Disaster84
- Регистриран на: Нед 16 юни 2013 7:12
- Автомобил: Passat 5 3B
- Двигател: AVF
- Местоположение: гр.Хасково
- dispatch
- Регистриран на: Сря 21 май 2008 20:33
- Автомобил: Passat В6 HighLine 2010
- Двигател: CBBB DSG6 02Е
- Местоположение: Павликени
Re: Пасат 3B 1,9ТDI 2001 няколко проблема?
На втори цилиндър Помпа-Дюзата, Електрически проблем. Най-вероятно буксата към самата дюза има не-добра връзка.
- Disaster84
- Двигател: AVF
Малко съм куц - как мога да стигна до тях?
- dispatch
Отваря се капака на клапаните и те са там.
Щом смяташ че си куц - по-добре я закарай на доктор.
- Disaster84
- Двигател: AVF
Oпределено :D, макар, че ми се струва проблема да е от горивната помпа или да съм и ударил някъде и да съм и смачкал тръбите за да не достига дебита... четох нещо подобно из форума
- Disaster84
- Двигател: AVF
За всички които се интересуват крайния резултат беше повредена помпа дюза на 2-ри цилиндър. Заменихме я с втора ръка дюза със същия номер и всички проблеми изчезнаха (за сега)
Потребители, разглеждащи този форум: Няма регистрирани потребители и 90 госта
