VCDS (VAG-COM) - работа и грешки
wargod
Регистриран на: Съб 12 яну 2013 16:29
Автомобил: VW Golf IV
Двигател: 1600 AKL - 2000
Местоположение: Бургас <-> София
Re: VCDS (VAG-COM) - работа и грешки
Мнениеот wargod » Нед 16 фев 2014 17:26
Здравейте, колеги. Колата е VW Golf IV 1.6 AKL 2000 Година. При компютърна диагностика ми излизат следните грешки:
Address 01: Engine Labels: 06A-906-019-AEH.lbl
Part No: 06A 906 019 BQ
Component: 1.6l 2V/R4 SIMOS HS3120
Coding: 00031
Shop #: WSC 01317
VCID: 73EFC11541AE091
2 Faults Found:
01177 - Engine Control Unit
37-10 - Faulty - Intermittent
00668 - Supply Voltage Terminal 30
36-00 - Open Circuit
Readiness: N/A
Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.lbl
Part No: 1J0 907 379 P
Component: ABS 20 IE CAN 0001
Coding: 03504
Shop #: WSC 01317
VCID: 3E7920213A6C949
No fault code found.
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 A
Component: 02 AIRBAG VW5 0004
Coding: 12338
Shop #: WSC 01317
VCID: 356B3F0D0F5A571
Address 17: Instruments Labels: 1J0-920-xx0-17.lbl
Part No: 1J0 920 801 B
Component: KOMBI+WEGFAHRS. BOO V28
Coding: 01143
Shop #: WSC 00000
VCID: 2143FB5DABD2CB1
Subsystem 1 - Part No: Ident
Component: Nr. WEGFAHRS.:VWZ6Z0Y1726663
Ident.-Nr. WEGFAHRS.:VWZ6Z0Y1726663
1 Fault Found:
01314 - Engine Control Module
49-00 - No Communications
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 01317
VCID: F0E54E19B0B8B29
1 Fault Found:
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 Q
Component: 4C Zentral-SG Komf. 0001
Coding: 04097
Shop #: WSC 01317
VCID: 4C9D7AE97CD0369
Subsystem 1 - Part No: 1J1959801C
Component: 4C Tхrsteuerger. FS0002r
Subsystem 2 - Part No: 1J1959802D
Component: 4C Tхrsteuerger. BF0002r
Subsystem 3 - Part No: 1J4959811C
Component: 4C Tхrsteuerger. HL0002r
Subsystem 4 - Part No: 1J4959812C
Component: 4C Tхrsteuerger. HR0002r
2 Faults Found:
00944 - Heated Exterior Mirror; Passenger Side (Z5)
35-00 - -
00935 - Electric Window Motor; Rear Right (V27)
35-10 - - - Intermittent
End ---------------------------------------------------------------------
Четох доста неща в интернет, но не намирам точни решения. Някой ако може да помогне, ще съм много благодарен!
Благодаря Ви предварително! :)
maxorka
Регистриран на: Пет 11 окт 2013 10:26
Автомобил: Polo 6N2 1.6i GTI
Двигател: AVY 2001
Мнениеот maxorka » Нед 16 фев 2014 19:43
:gruebel
http://store.picbg.net/pubpic/12/A5/22e12325ebdb12a5.png
http://picbg.net/img.php?file=6d32c9a38bc0b6ca.png
На мен ли ми се струва или въпросните показатели са разменени?
Последна промяна от maxorka на Пон 17 фев 2014 21:12, променено общо 2 пъти.
vankoni
Регистриран на: Пет 02 май 2008 16:46
Автомобил: VW passat B3 B5.5
Двигател: PF1991 ALT2003
Местоположение: Хисар London
Мнениеот vankoni » Нед 16 фев 2014 23:24
Здравейте колеги, нормално ли е 66С градуса на входящ въздух при 10С външна? Б5.5 АЛТ 2.0 130
van4ooo
Мнениеот van4ooo » Вто 18 фев 2014 13:07
Може да не затваря добре клапата за топъл/студен въздух,сравни темп на антифриза и входящия въздух без да си палил колата.
Защо влизаш в това меню за тези данни при положение,че си с vw ?
vankoni
Мнениеот vankoni » Вто 18 фев 2014 23:00
Не съм много на "ти" с тази програма, колата ми има проблем с отчитането на температурата, мудна и тромава с висок разход. Другото което ме притеснява е много ниските обороти на празен ход 750/мин !
klimatronik
Регистриран на: Съб 24 ное 2007 16:31
Автомобил: Golf TDI PD+PASSAT B8 CR TDI 190
Мнениеот klimatronik » Сря 19 фев 2014 19:13
Колеги имам един въпрос. Имам кабел vag com 409.1 и работя с регистрирана VCDS lite. Закачал съм над 15 коли и винаги всичко е било безпроблемно. Днес закачах едно Ауди А3 на един приятел, 1,8 125к.с. '97г. Влизам във всички контролери като ABS, Air bags и т.н, но немога да влезна в Engine- изписва No response from controller. Някой има ли идея в какво се състои проблема- в колата или нещо при мен?
maxorka
Двигател: AVY 2001
Мнениеот maxorka » Сря 19 фев 2014 20:39
1 Fault Found:
17927 - Camshaft Adjustment; Bank 1: Malfunction
P1519 - 35-00 - -
Звяра вади грешката вече няколко дена подред.Появява се най-често в движение като светва лампата за ESP-то и колата влиза в авариен или както е там режим-Няма мощност,няма ЕСП.Странното е,че като я изгася и запаля отново се случват 2 варианта-или пали веднага и няма проблем,или не пали от 3-4 опита,но след това Engine Check-a остава да свети и вади същата грешка в заедно с нова
2 Faults Found:
P1519 - 35-10 - - - Intermittent
16706 - Engine Speed Sensor (G28): No Signal
P0322 - 35-10 - - - Intermittent
Kъде се намира въпросният G28 датчик,който според AutoData cе ползва и за Crankshaft position sensor(Позиционен датчик колянов вал до колкото разбирам)
За първата грешка това ли въпросния клапан тук и тук.
Какви показания трябва да имат при замерване с мултиметър самите датчици.?А кабелите към ECU-то?
Не ми се сменят на поразия за по ХХХлв и после да излезе кабел или нещо друго?
minimalizum
Регистриран на: Сря 05 авг 2009 23:31
Автомобил: OCT1
Двигател: AHF
Местоположение: ПЛОВДИВ - - -
Мнениеот minimalizum » Чет 20 фев 2014 0:20
klimatronik написа:Колеги имам един въпрос. Имам кабел vag com 409.1 и работя с регистрирана VCDS lite. Закачал съм над 15 коли и винаги всичко е било безпроблемно. Днес закачах едно Ауди А3 на един приятел, 1,8 125к.с. '97г. Влизам във всички контролери като ABS, Air bags и т.н, но немога да влезна в Engine- изписва No response from controller. Някой има ли идея в какво се състои проблема- в колата или нещо при мен?
Влез в OPtions i смени скоростта на връзка ( START BAUD ) na 9600
Може да влезеш тогава пък само в ENGIne :)
klimatronik
Мнениеот klimatronik » Чет 20 фев 2014 8:52
Ще го пробвам. Много благодаря :th_up :th_up
kkachovski
Регистриран на: Сря 28 авг 2013 8:56
Автомобил: VW Passat B6 3C2
Двигател: BLS 2009
Местоположение: София/Враца
Мнениеот kkachovski » Съб 22 фев 2014 18:20
Здравейте колеги,
имам следния въпрос....
Address 01: Engine (03G 906 021 PB)
09:27:38 Group 075
234.0°C Temperature
294.0°C Temperature
17.0 % Duty Cycle
558.0°C Temperature
09:27:38 Group 003
777 /min RPM
220.0 mg/str Mass Air / Rev.
395.0 mg/str Mass Air / Rev.
100.6 % Duty Cycle
09:27:38 Group 011
798 /min RPM
1091.4 mbar Absolute Pres.
958.8 mbar Absolute Pres.
72.6 % Duty Cycle
при оградените с червено стойности и рязко подаване на газ на около 1800 оборота се усеща разтрисане от двигателя след което турбото изфучава зверски и се дърпа нормално (но звука не е нормален) и при отнемане рязко на газта в интервала 1800-2500об. колата реагира на отнемането от газта със забавяне което е съпроводено пак със силно фучене от турбото. Стойността 100.6 % Duty Cycle не мърда при никакви условия.
Тези немоера ги прави на няколко дни, но днес когато всичко беше нормално тази стойност от 100,6% на тихи обороти седи около 70-80% и при ускорение се мени, както и другите 2 стойности се движат паралелно.
ka4o_pi4a
Регистриран на: Пет 13 юли 2012 12:00
Автомобил: Seat Leon
Двигател: ASV 2002
Местоположение: Благоевград
Мнениеот ka4o_pi4a » Нед 23 фев 2014 12:35
Здравейте. Имате ли представа защо когато се изключи Service Reminder Interval през адаптациите на 07-Instuments, след това когато искам да го пусна ми дава ERROR ?
Редакция: Оправих се - оказа се че Service Reminder Interval не може да се спира, а само да се ресетва или да му се сменяват стойностите. Когато се запише "0" стойност се ресетва и стойността става "1" когато брояча достигне 10 хил. км. например.
alex2811
Регистриран на: Сря 02 ное 2011 13:32
Автомобил: Golf 4 1.9 TDI
Двигател: AJM 2000
Местоположение: ruse
Мнениеот alex2811 » Вто 25 фев 2014 13:33
Колеги имам един приятел с голф 3 1.8 бензин 97г. имаше волан с air bag обаче го махна и си сложи спортен волан и сега му свети лампата на air bag-а та мисълта ми е дали може да се изключи тази лампа да не свети с vag com и как става това? :gruebel
rulavw
Регистриран на: Сря 26 фев 2014 1:25
Мнениеот rulavw » Сря 26 фев 2014 1:42
без лъжа не става ! може да се изключи лампа да не свети с vag com ,но преди това 2-3 ома резистор вместо "air bag" и нулиране на грешката. но по-добре с "air bag"
zografski
Регистриран на: Сря 25 мар 2009 18:10
Автомобил: Golf IV V6 4Motion
Двигател: AUE 2001
Мнениеот zografski » Сря 05 мар 2014 15:56
Като за начало трябва да се погледне датчика за температурата Sensor (G62).
17931 - Crash Signal from Airbag Controller
проверете кабелите и буксите на Airbag-а.
17748 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28)
http://wiki.ross-tech.com/wiki/index.php/17748/P1340/004928
http://wiki.ross-tech.com/wiki/index.php/16725/P0341/000833
dedicha
Регистриран на: Чет 07 май 2009 23:29
Автомобил: Toledo2 Leon3 VW Golf 4
Двигател: 101HP 115HP TSI 115HP FSI
Мнениеот dedicha » Пон 10 мар 2014 17:39
Колеги, предстои ми смяна на таблото, имам регстриран VCDS-lite, има ли начин да се прехвърлят километрите от старото на новото(втора употреба разбира се) табло ? И има ли как да се видят реалните километри през VCDS-lite, ако старото табло е пипано? :beer
