Passat B 5.5 2003g. AVF проблем ECU или нещо друго РЕШЕН!!!
hi4umir4uu
Регистриран на: Вто 23 юни 2009 13:28
Автомобил: Passat b7
Двигател: EcoFuel
Мнениеот hi4umir4uu » Пет 12 сеп 2014 14:58
Колеги вчера си жземах въпросният Пасат и до преди малко всичко беше ок, сутринта я карах нямаше никакви проблеми, но преди малко при тръгване още започна да тресе, да не иска да сменя скорости. Колата е Пасат Б5.5 2003г. ТДИ 131к.с. автоматик. При диагностика искара следните грешки:
VCDS Version: Beta 12.10.6
Data version: 20130531
Friday,12,September,2014,15:13:44:51315
Chassis Type: 3B - VW Passat B5
Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
VIN: WVWZZZ3BZ3E424929 Mileage: 140540km/87327miles
Address 01: Engine Labels: 038-906-019-AVF.lbl
Part No: 038 906 019 GQ
Component: 1,9l R4 EDC 0000AG 1582
Coding: 00001
Shop #: WSC 05314
VCID: 6CDB47B31F8BF763CFB
WVWZZZ3BZ3E424929 VWZ7Z0C7492396
1 Fault Found:
18077 - PD Unit Injector; Cylinder 4 (N243)
P1669 - 35-00 - Electrical Malfunction
Readiness: 0 0 X X X
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 3B0 927 156 S
Component: AG5 01V 1.9l-PD RdW 2224
Coding: 00103
Shop #: WSC 01652
VCID: 366FA5DB11477DB3E9F
1 Fault Found:
18265 - Load Signal
P1857 - 35-00 - Error Message from ECU
Address 03: ABS Brakes Labels: 4B0-614-517.lbl
Part No: 4B0 614 517 G
Component: ABS/ESP front 3428
Coding: 04257
Shop #: WSC 05311
VCID: 254D7297BCE1062B505
1 Fault Found:
18265 - Load Signal
P1857 - 35-10 - Error Message from ECU - Intermittent
Address 08: Auto HVAC Labels: 3Bx-907-044.lbl
Part No: 3B1 907 044 K
Component: CLIMATRONIC B5GP 0010
Coding: 17000
Shop #: WSC 05311
VCID: 29557EA7D0F9224B74D
3 Faults Found:
00603 - Footwell/defroster Flap Positioning Motor (V85)
35-10 - - - Intermittent
01271 - Positioning Motor for Temperature Flap (V68)
01274 - Air Flow Flap Positioning Motor (V71)
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 C
Component: 08 AIRBAG VW61 04 0003
Coding: 12344
Shop #: WSC 05311
VCID: 244B6F93B7DBFF2347B
No fault code found.
Address 17: Instruments Labels: 3B0-920-xx5-17.lbl
Part No: 3B0 920 827 A
Component: KOMBI+WEGFAHRSP VDO V08
Coding: 05115
Shop #: WSC 00000
VCID: 2247698BADCFF113357
1 Fault Found:
01314 - Engine Control Module
49-10 - No Communications - Intermittent
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 05311
VCID: F0E3D3C3B3A39383733
1 Fault Found:
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 B
Component: 8S Komfortgerat HLO 0003
Coding: 00259
Shop #: WSC 01652
Subsystem 1 - Part No: 1C0959801
Component: 8S Torsteuer.FS KLO 0009
Subsystem 2 - Part No: 1C0959802A
Component: 8S Torsteuer.BF KLO 0009
Subsystem 3 - Part No: 1C0959811
Component: 8S Torsteuer.HL KLO 0009
Subsystem 4 - Part No: 1C0959812
Component: 8S Torsteuer.HR KLO 0009
1 Fault Found:
01359 - Internal Central Locking Switch; Passenger Side (E198)
27-10 - Implausible Signal - Intermittent
Address 55: Xenon Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00007
Shop #: WSC 05314
VCID: 040B0F13171B1F2327B
2 Faults Found:
00774 - Level Control System Sensor; Rear Left (G76)
28-10 - Short to Plus - Intermittent
00776 - Level Control System Sensor; Left Front (G78)
Address 56: Radio Labels: 1J0-035-18x-56.lbl
Part No: 1J0 035 186 E
Component: Radio BNO 0006
Coding: 05403
Shop #: WSC 05311
VCID: 2751789FC6ED143B629
1 Fault Found:
00852 - Loudspeaker(s); Front
36-00 - Open Circuit
Address 76: Park Assist Labels: 3B0-919-283.lbl
Part No: 3B0 919 283
Component: Parkingsyst. PA RDW D01
Coding: 01114
Shop #: WSC 05314
VCID: E5CDB2977C61462B105
End ---------------------------------------------------------------------
:banghead :banghead :banghead :banghead :banghead :banghead :banghead :banghead
Аз от тези грешки нищо не разбирам и нищо не ми говорят, ако някой може да помогне с нещо ще съм благодарен
Последна промяна от hi4umir4uu на Нед 14 сеп 2014 21:59, променено общо 1 път.
dispatch
Регистриран на: Сря 21 май 2008 20:33
Автомобил: Passat В6 HighLine 2010
Двигател: CBBB DSG6 02Е
Местоположение: Павликени
Re: Passat B 5.5 2003g. AVF ПРОБЛЕМ ECU или нещо друго
Мнениеот dispatch » Пет 12 сеп 2014 20:23
Бая грешки си насъбрал....
Причината за тресенето е ето тази:
1 Fault Found:
Вероятно имаш проблем с буксата на ПД-инжектора на 4-ти цилиндър. А тази букса се намира под капака на клапаните.
Един страничен въпрос: От къде е внос автомобила и колко пари брои? :smile
hi4umir4uu
Двигател: EcoFuel
Мнениеот hi4umir4uu » Пет 12 сеп 2014 22:51
тази вечер ходих на майстор и ми казаха, че всичките грешки най-вероятно идвали от четвъртия цилиндър и от огромното тресене на двигателя, но тези дни ще ходя и до още един сервиз за всеки случай дано да се окаже че е само от буксата ане от дюзи или валове или всичко накуп
иначе колата евнос от Италия (Верона) а цената е малко над 6 бона
yanio
Регистриран на: Сря 06 май 2009 14:12
Местоположение: БГ
Мнениеот yanio » Пет 12 сеп 2014 23:47
няма как всички грешки да са от четвъртия цилиндър. климатроникът ти е записал бая грешки , както и ксенона. Сигурно фаровете ти в момента не се саморегулират ? Иначе тресенето е най-вероятно от буксата на дюзата или самата дюза е разхлабена. Едва ли ще е умряла :)
hi4umir4uu
Двигател: EcoFuel
Re: Passat B 5.5 2003g. AVF проблем ECU или нещо друго
Мнениеот hi4umir4uu » Съб 13 сеп 2014 13:21
За щастие проблема решен
Оказа се хлабава клема на дюзата на четвъртия цилиндър след почистване и леко стягане всичко си дойде на мястото.
Мерси на всички за мненията и помоща
Потребители, разглеждащи този форум: pe6o__ и 67 госта
