Шаран 1.9 TDI AUY-2001г. грешки
DIMITER1
Регистриран на: Пет 24 фев 2012 8:50
Местоположение: Видин
Мнениеот DIMITER1 » Чет 05 мар 2015 10:15
Здравейте колеги,
Ако някой може да ми помегнем да разшифровам грешките ,който изкарва въпросния Шаран,след AUTO SCAN с VCDS,
и да попитам,възможно ли е колата да прегрява и да надува маркучите от грешката в AUX.HEAT...
Ето това е AUTO SCANA...
Благодаря предварително...
Thursday,26,February,2015,10:50:09:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: WVWZZZ7MZ1V048724 License Plate:
Mileage: 153870km-95610mi Repair Order:
Chassis Type: 7M (7M - VW Sharan (1996 > 2010))
Scan: 25 01 02 03 08 09 15 16 17 18 19 22 29 35 36 37 39 45 55 56
76
VIN: WVWZZZ7MZ1V048724 Mileage: 153870km/95610miles
Address 25: Immobilizer Labels: 7M3-953-257.lbl
Part No: 7M3 953 257
Component: IMMO 0008
Coding: 00003
Shop #: WSC 00000
VCID: F6E38053D23266AE3EF-49D8
WVWZZZ7MZ1V048724 VWZ1Z0A1262331
No fault code found.
Address 01: Engine Labels: 038-906-019-AJM.lbl
Part No: 038 906 019 ET
Component: 1,9l R4 EDC G001SG 1268
Coding: 00002
Shop #: WSC 00020
VCID: 6DD12F3F276425764F5-49D8
Readiness: 0 0 X X X
Address 03: ABS Brakes Labels: 1J0-907-37x-ESP-A.lbl
Part No: 7M3 907 379 C
Component: ESP 20 CAN V003
Coding: 18443
Shop #: WSC 00020
VCID: 3D71DF7F378475F6BF5-49D8
Address 08: Auto HVAC Labels: 7M3-907-040.clb
Part No: 7M3 907 040 B
Component: CLIMATRONIC MPV GP 0003
Coding: 00010
Shop #: WSC 00020
VCID: 2D51EF3FE7E4E5760F5-2566
1 Fault Found:
01086 - Speedometer Sensor (G22)
35-10 - - - Intermittent
Address 09: Cent. Elect. Labels: None
Part No: 7M3 962 258 M
Component: Multifunkt.Einh 0001
Coding: 04097
Shop #: WSC 00020
VCID: 4487AA9B546E043EF0B-4F8E
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605
Component: 0Q AIRBAG VW5 0G 0006
Coding: 12369
Shop #: WSC 00020
VCID: F4E7BA5BC44E74BE00B-4A3A
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 7Mx-920-xxx-17.lbl
Part No: 7M3 920 840 GX
Component: KOMBIINSTRUMENT VDO V30
Coding: 13121
Shop #: WSC 11111
VCID: 8D11CFBFC7A405766F5-5000
Address 18: Aux. Heat Labels: 7M3-815-071.clb
Part No: 7M3 815 071
Component: HEIZG. B/D5W 0001
VCID: EDD1AF3FA764A576CF5-5072
2 Faults Found:
65535 - Internal Control Module Memory Error
00-00 - -
01410 - Heater Over-Temp
06-00 - Signal too High
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 00000
VCID: F0EFB64BB056489EE43-5000
1 Fault Found:
00778 - Steering Angle Sensor (G85)
49-10 - No Communications - Intermittent
Address 22: AWD Labels: 02D-900-554.lbl
Part No: 02D 900 554 B
Component: HALDEX LSC ECC 0006
VCID: 1F4D05F79D4807E68D9-4A3A
1 Fault Found:
00526 - Brake Light Switch-F
27-10 - Implausible Signal - Intermittent
Address 56: Radio Labels: 1J0-035-15x-56.lbl
Part No: 1J0 035 152 F
Component: Radio BNO 0005
Coding: 00001
Shop #: WSC 00020
VCID: 2149030FAB3C3116BBD-49D8
1 Fault Found:
00852 - Loudspeaker(s); Front
36-10 - Open Circuit - Intermittent
End ---------------------------------------------------------------------
mccoy
Регистриран на: Нед 11 ное 2007 23:16
Автомобил: HONDA CRV III 2.2 I-CTDI
Двигател: N22A2
Re: Грешки на ШАРАН 1.9 TDI AUY-2001г.
Мнениеот mccoy » Чет 05 мар 2015 14:53
Изтрий всички грешки, карай 10-15км. и сканирай пак.
Повечето грешки са стари и няма да се появят пак.
грешката "Address 18: Aux. Heat" е от допълнителния отоплител (печка)който е прегрял най-вероятно от не работеща помпа ,но от това не може да прегрее двигателя.
За другите грешки ще говорим след новото сканиране.
tisho_70
Регистриран на: Съб 10 окт 2015 14:11
Re: Шаран 1.9 TDI AUY-2001г. грешки
Мнениеот tisho_70 » Нед 03 яну 2016 17:42
Sunday,03,January,2016,12:56:57:62939
VIN: WVWZZZ7MZ1V002368 License Plate:
76
VIN: WVWZZZ7MZ1V002368 Mileage: 159900km/99357miles
Address 25: Immobilizer Labels: 6X0-953-257.lbl
Part No: 6X0 953 257
Component: IMMO 0003
Coding: 00003
Shop #: WSC 45616
VCID: FDF19F7FF70435F67F5-49D8
WVWZZZ7MZ1V002368 VWZ1Z0Y0454192
1 Fault Found:
01176 - Key
65-10 - Unauthorized - Intermittent
Part No: 038 906 019 J
Component: 11,9l R4 EDC 0000SG 1087
Coding: 00002
Shop #: WSC 00020
VCID: 1E3338F39A420EEE86F-4A3A
3 Faults Found:
19464 - Camshaft Position Sensor (G40)
P3008 - 35-00 - Signal Out of Range
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-00 -
17965 - Charge Pressure Control
P1557 - 35-00 - Positive Deviation
Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.lbl
Part No: 1J0 907 379 P
Component: ABS 20 IE CAN 0001
Coding: 12502
Shop #: WSC 00020
VCID: 3E73D8733A826EEEA6F-4A3A
Part No: 7M3 907 040 A
Component: CLIMATRONIC MPV GP 0001
Coding: 00010
Shop #: WSC 00020
VCID: 2C57E23BDCFEEC7E18B-2566
1 Fault Found:
01596 - Motor for Outside/Recirculated Air Flap (V154)
35-00 - -
Part No: 7M3 962 258 G
Component: Multifunkt.Einheit 0001
Coding: 16385
Shop #: WSC 00020
VCID: 3E73D8733A826EEEA6F-4F8E
3 Faults Found:
01148 - Activation of Safety/Deadbolt Locks in Doors
29-10 - Short to Ground - Intermittent
01149 - Deactivation of Safety/Deadbolt Locks in Doors
28-10 - Short to Plus - Intermittent
00978 - Lamp for Low Beam; Left (M29)
30-10 - Open or Short to Plus - Intermittent
Component: 0A AIRBAG VW5 09 0004
Coding: 12353
Shop #: WSC 00020
1 Fault Found:
Part No: 7M3 920 840 C
Component: KOMBIINSTRUMENT VDO V04
Coding: 01021
Shop #: WSC 54321
VCID: 3169F34FFBDC81962BD-5000
9 Faults Found:
06-10 - Signal too High - Intermittent
00779 - Outside Air Temp Sensor (G17)
00667 - Ambient Temperature Signal
01177 - Engine Control Unit
64-10 - Not Currently Testable - Intermittent
01316 - ABS Control Module
79-00 - Please Check Fault Codes
01336 - Data Bus for Comfort System
80-00 - Single-Wire Operation
VCID: EDD1AF3FA764A576CF5-5000
5 Faults Found:
01491 - Glow-Plug for Heater (Q9)
36-00 - Open Circuit
Coding: 00006
Shop #: WSC 00020
1 Fault Found:
Address 56: Radio Labels: 1J0-035-18x-56.lbl
Part No: 1J0 035 186 E
Component: Radio BNO 0004
Coding: 00401
Shop #: WSC 00020
VCID: 275D1D17C518CF26F59-49D8
2 Faults Found:
00853 - Loudspeaker(s); Rear
Пълен с грешки съм:(
mccoy
Двигател: N22A2
Мнениеот mccoy » Нед 03 яну 2016 23:23
Хвърляй го за скрап
ИЛИ
Прочети горното мнение
tisho_70
Мнениеот tisho_70 » Пон 04 яну 2016 21:07
Хаххх,в БГ сме,ако за неработеща печка си готов да си засилиш колата за скраб-твоя работа.Пуснал съм грешките тук преди да ги изтрия ,с надежда някой разбиращ да ме светне преди да съм оплескал добре работеща кола.
Все пак ти благодаря за мнението
okti_1
Регистриран на: Вто 04 сеп 2012 21:08
Местоположение: Асеновград
Мнениеот okti_1 » Пон 04 яну 2016 21:23
Много работа има по Шаранчето,но съм обеден че ще стане.Иска ровичкане и четене много.
tisho_70
Мнениеот tisho_70 » Пон 04 яну 2016 21:46
Ще видя кво ше остане като ги тръкна:)
mccoy
Двигател: N22A2
Мнениеот mccoy » Вто 05 яну 2016 0:27
tisho_70 написа:Хаххх,в БГ сме,ако за неработеща печка си готов да си засилиш колата за скраб-твоя работа.Пуснал съм грешките тук преди да ги изтрия ,с надежда някой разбиращ да ме светне преди да съм оплескал добре работеща кола.
Щом предпочиташ вместо да прочетеш едно мнение ....
Дано се намери някой да ти тълкува всички грешки натрупани през последните години.
Наистина ще оплескаш нещо ако тръгнеш да ремонтираш несъществуващи повреди
tisho_70
Мнениеот tisho_70 » Вто 05 яну 2016 9:07
Малко инфо от днес:
Tuesday,05,January,2016,08:53:42:62939
VIN: WVWZZZ7MZ1V002368 License Plate: 5.01
Mileage: 159930km-99375mi Repair Order:
76
VIN: WVWZZZ7MZ1V002368 Mileage: 159930km/99375miles
Coding: 00003
Shop #: WSC 45616
VCID: FDF19F7FF70435F67F5-4A3A
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Coding: 00002
Shop #: WSC 00020
VCID: 1E3338F39A420EEE86F-49D8
Coding: 12502
Shop #: WSC 00020
VCID: 3E73D8733A826EEEA6F-49D8
Coding: 00010
Shop #: WSC 00020
1 Fault Found:
35-00 - -
Coding: 16385
Shop #: WSC 00020
VCID: 3E73D8733A826EEEA6F-5000
Coding: 12353
Shop #: WSC 00020
Coding: 01021
Shop #: WSC 54321
Coding: 00006
Shop #: WSC 00020
Coding: 00401
Shop #: WSC 00020
VCID: 275D1D17C518CF26F59-4A3A
mccoy
Двигател: N22A2
Мнениеот mccoy » Вто 05 яну 2016 23:56
е това е друго нещо
Имаш една грешка на климатроника на клапата за чист въздух, в моторчето което я задвижва една зъбчатка се пука и спира да движи клапата.
Ново моторче беше над 200лв. но с малко сръчност и помощ от стругар може да се ремонтира старото.
Лошата новина е че се сваля цялото табло.
За начало можеш да сложиш един картон пред филтъра на купето за да не влиза студен въздух ,че и без това е трудно стоплянето.
На печката няма грешки. Тя аботи ли ?
tisho_70
Мнениеот tisho_70 » Сря 06 яну 2016 0:24
Скивах тоз мотор за свеж въздух,утре ще проверя дали не е от пасажерската страна,стругар и фрезист имам под ръка,печката не бачка,намерих майстор в Добрич,въпрос на време е кога ще го навестя,има доста писано за нея при руснаците,но без канал не мога нищо да направя.
За колеги с подобен проблем:
http://www.polo9n.info/Wissen/anleitung ... n-tauschen
