1,9 TDI AHF проблем с центровка на ГНП
- Георги.Георгиев15
- Регистриран на: Сря 18 яну 2017 22:42
- Автомобил: VW GOLF
- Двигател: AHF 1999
Re: 1,9 TDI AHF проблем с центровка на ГНП
Както казах в по горния пост свалях турбината и я почисъих прегледах всичко и работи нормално вакумите съм сменил единствено н75 не съм го пипал едно малко клапанпе от едната страна е бяло направи ми впечатление че като го продухах започна да тече масло от него. А с паленето като наглася вдичко да е в норми върти много време и накрая изкарва бял пушек и започва да пуши
- Георги.Георгиев15
ето и лог на 4 канал
Код: Избери всички
Thursday,07,February,2019,18:09:07
038 906 012 L,, 1.9l R4 EDC 0000SG 2812,
,Group A:,'004,,,,Group B:, Not Running,,,,Group C:, Not Running
,,RPM,Ign. Timing,Ign. Timing,Duty Cycle,,,,,,,,,,
,TIME,,,,,TIME,,,,,TIME,,,,
Marker,STAMP, /min, °BTDC, °BTDC, %,STAMP,,,,,STAMP,,,,
,0.00,903,1.3,1.8,2.8,,,,,,,,,,
,0.36,903,1.3,1.5,2.8,,,,,,,,,,
,0.70,903,1.3,1.5,2.8,,,,,,,,,,
,1.06,903,1.3,1.8,2.8,,,,,,,,,,
,1.42,882,1.3,1.8,2.8,,,,,,,,,,
,1.78,903,1.3,1.5,2.8,,,,,,,,,,
,2.12,903,1.3,1.3,3.2,,,,,,,,,,
,2.48,903,1.3,1.3,4.0,,,,,,,,,,
,2.84,903,1.3,1.5,5.2,,,,,,,,,,
,3.18,903,1.3,1.3,4.4,,,,,,,,,,
,3.53,903,1.3,1.5,2.8,,,,,,,,,,
,3.87,903,1.3,1.1,2.8,,,,,,,,,,
,4.22,903,1.3,1.3,2.8,,,,,,,,,,
,4.58,903,1.3,1.5,2.8,,,,,,,,,,
,4.93,903,1.3,1.5,2.8,,,,,,,,,,
,5.28,903,1.3,1.8,2.8,,,,,,,,,,
,5.64,903,1.3,1.8,2.8,,,,,,,,,,
,6.00,903,1.3,1.3,2.8,,,,,,,,,,
,6.34,903,1.3,1.3,2.8,,,,,,,,,,
,6.70,903,1.3,1.3,2.8,,,,,,,,,,
,7.06,756,2.6,1.5,14.7,,,,,,,,,,
,7.42,882,1.3,0.4,23.1,,,,,,,,,,
,7.76,945,1.3,0.9,33.1,,,,,,,,,,
,8.12,945,1.3,0.7,6.8,,,,,,,,,,
,8.48,1029,0.0,0.0,21.9,,,,,,,,,,
,8.84,1050,0.0,0.0,21.9,,,,,,,,,,
,9.20,1029,0.0,0.0,21.9,,,,,,,,,,
,9.56,1008,0.2,0.0,21.5,,,,,,,,,,
,9.92,1008,0.2,0.0,21.9,,,,,,,,,,
,10.26,1008,0.2,0.0,21.9,,,,,,,,,,
,10.61,1008,0.2,0.0,21.9,,,,,,,,,,
,10.95,819,1.3,0.0,23.1,,,,,,,,,,
,11.31,882,1.3,5.1,2.8,,,,,,,,,,
,11.65,903,1.3,4.2,2.8,,,,,,,,,,
,12.01,903,1.3,2.9,2.8,,,,,,,,,,
,12.36,903,1.3,2.4,2.8,,,,,,,,,,
,12.72,903,1.3,2.2,4.0,,,,,,,,,,
,13.07,903,1.3,2.0,3.2,,,,,,,,,,
,13.42,903,1.3,2.0,2.8,,,,,,,,,,
,13.76,903,1.3,2.0,4.4,,,,,,,,,,
,14.12,903,1.3,1.5,5.2,,,,,,,,,,
,14.48,882,1.3,1.3,5.6,,,,,,,,,,
,14.84,1071,0.7,1.3,16.3,,,,,,,,,,
,15.18,945,2.6,2.0,19.9,,,,,,,,,,
,15.53,966,2.4,1.3,25.1,,,,,,,,,,
,15.89,1218,0.0,1.3,18.7,,,,,,,,,,
,16.23,1491,1.3,1.1,2.8,,,,,,,,,,
,16.59,1806,1.8,1.1,2.8,,,,,,,,,,
,16.95,1554,1.8,2.4,2.8,,,,,,,,,,
,17.31,1113,0.0,0.0,30.3,,,,,,,,,,
,17.67,1134,0.0,4.8,2.8,,,,,,,,,,
,18.01,1155,0.2,4.8,2.8,,,,,,,,,,
,18.36,1155,0.2,5.1,2.8,,,,,,,,,,
,18.70,1218,0.9,5.1,2.8,,,,,,,,,,
,19.06,1260,0.9,4.8,2.8,,,,,,,,,,
,19.42,1260,0.9,4.8,2.8,,,,,,,,,,
,19.78,1302,0.4,0.0,19.5,,,,,,,,,,
,20.12,1260,0.7,0.0,20.3,,,,,,,,,,
,20.46,1281,0.7,0.0,19.9,,,,,,,,,,
,20.81,1281,0.4,5.9,2.8,,,,,,,,,,
,21.17,1302,0.4,6.2,2.8,,,,,,,,,,
,21.53,1302,0.2,5.7,2.8,,,,,,,,,,
,21.89,1365,0.2,5.5,2.8,,,,,,,,,,
,22.23,1344,0.2,5.7,2.8,,,,,,,,,,
,22.59,1386,0.4,5.7,2.8,,,,,,,,,,
,22.95,1365,0.2,5.5,2.8,,,,,,,,,,
,23.31,1365,0.2,0.0,18.3,,,,,,,,,,
,23.65,1323,0.0,0.0,18.7,,,,,,,,,,
,24.00,1302,0.2,0.0,19.9,,,,,,,,,,
,24.34,1302,0.2,0.0,20.7,,,,,,,,,,
,24.70,1323,0.0,0.0,21.1,,,,,,,,,,
,25.06,1323,0.0,6.2,23.1,,,,,,,,,,
,25.42,1323,0.0,6.2,2.8,,,,,,,,,,
,25.76,1323,0.0,6.4,2.8,,,,,,,,,,
,26.11,1302,0.2,5.9,2.8,,,,,,,,,,
,26.47,1302,0.4,0.0,2.8,,,,,,,,,,
,26.83,1281,0.4,0.0,19.9,,,,,,,,,,
,27.19,1302,0.4,0.0,20.3,,,,,,,,,,
,27.54,1281,0.4,0.0,19.9,,,,,,,,,,
,27.91,1260,0.9,0.0,23.5,,,,,,,,,,
,28.26,1260,0.9,6.2,2.8,,,,,,,,,,
,28.61,1239,0.9,5.9,2.8,,,,,,,,,,
,28.95,1260,0.9,5.9,2.8,,,,,,,,,,
,29.31,1260,0.9,0.0,22.7,,,,,,,,,,
,29.67,1239,1.1,0.0,23.5,,,,,,,,,,
,30.03,1260,0.9,0.0,24.7,,,,,,,,,,
,30.37,1197,0.9,0.0,20.3,,,,,,,,,,
,30.73,1176,0.7,0.0,21.1,,,,,,,,,,
,31.07,1176,0.7,0.0,21.5,,,,,,,,,,
,31.43,1197,0.9,6.2,2.8,,,,,,,,,,
,31.79,1218,1.1,0.0,24.3,,,,,,,,,,
,32.13,1302,0.2,5.7,2.8,,,,,,,,,,
,32.48,1302,0.4,5.9,22.7,,,,,,,,,,
,32.83,1260,0.7,0.0,21.5,,,,,,,,,,
,33.19,1260,0.7,0.0,21.9,,,,,,,,,,
,33.55,1281,0.4,0.0,21.5,,,,,,,,,,
,33.90,1281,0.4,0.0,22.3,,,,,,,,,,
,34.26,1281,0.4,6.2,2.8,,,,,,,,,,
,34.63,1302,0.4,6.4,2.8,,,,,,,,,,
,34.98,1323,0.2,6.2,2.8,,,,,,,,,,
,35.34,1344,0.0,5.9,2.8,,,,,,,,,,
,35.68,1365,0.2,5.7,2.8,,,,,,,,,,
,36.03,1344,0.2,6.2,2.8,,,,,,,,,,
,36.39,1386,0.4,5.7,2.8,,,,,,,,,,
,36.75,1365,0.2,5.7,2.8,,,,,,,,,,
,37.11,1386,0.4,0.0,18.3,,,,,,,,,,
,37.46,1365,0.2,0.0,18.7,,,,,,,,,,
,37.82,1344,0.0,0.0,19.1,,,,,,,,,,
,38.17,1302,0.2,0.0,19.5,,,,,,,,,,
,38.51,1281,0.4,0.0,19.9,,,,,,,,,,
,38.86,1302,0.2,0.0,19.5,,,,,,,,,,
,39.22,1260,0.9,0.0,20.3,,,,,,,,,,
,39.58,1260,0.9,0.0,19.9,,,,,,,,,,
,39.93,1239,1.1,0.0,20.7,,,,,,,,,,
,40.28,1239,1.1,0.0,20.7,,,,,,,,,,
,40.64,1218,1.1,0.0,20.3,,,,,,,,,,
,40.98,1197,0.9,0.0,20.7,,,,,,,,,,
,41.34,1155,0.4,0.0,22.3,,,,,,,,,,
,41.68,1155,0.4,0.0,27.1,,,,,,,,,,
,42.04,1113,0.2,0.0,24.3,,,,,,,,,,
,42.39,1092,0.0,0.0,24.7,,,,,,,,,,
,42.75,1092,0.0,0.0,26.3,,,,,,,,,,
,43.09,1071,0.0,0.0,25.1,,,,,,,,,,
,43.43,1050,0.0,0.0,25.1,,,,,,,,,,
,43.78,1050,0.0,0.0,24.7,,,,,,,,,,
,44.14,1029,0.2,4.4,2.8,,,,,,,,,,
,44.50,1029,0.2,0.0,22.3,,,,,,,,,,
,44.86,1008,0.4,0.0,27.1,,,,,,,,,,
,45.22,1008,0.4,0.0,23.5,,,,,,,,,,
,45.58,987,0.4,0.0,25.5,,,,,,,,,,
,45.93,987,0.4,4.2,2.8,,,,,,,,,,
,46.28,987,0.4,0.0,23.9,,,,,,,,,,
,46.64,966,0.4,0.0,23.1,,,,,,,,,,
,47.00,987,0.4,0.0,22.3,,,,,,,,,,
,47.36,966,0.7,4.4,2.8,,,,,,,,,,
,47.72,966,0.4,0.0,22.3,,,,,,,,,,
,48.07,987,0.4,0.0,23.9,,,,,,,,,,
,48.42,987,0.4,0.0,23.1,,,,,,,,,,
,48.78,1008,0.2,0.0,2.8,,,,,,,,,,
,49.14,1008,0.2,0.0,24.3,,,,,,,,,,
,49.48,1029,0.2,0.0,21.9,,,,,,,,,,
,49.82,1029,0.2,0.0,23.5,,,,,,,,,,
,50.17,1050,0.0,0.0,21.9,,,,,,,,,,
,50.53,1050,0.0,0.0,21.9,,,,,,,,,,
,50.89,1050,0.0,0.0,23.1,,,,,,,,,,
,51.25,1071,0.0,0.0,21.5,,,,,,,,,,
,51.59,1050,0.0,0.0,25.5,,,,,,,,,,
,51.95,1071,0.0,0.0,24.3,,,,,,,,,,
,52.31,1071,0.0,4.4,23.9,,,,,,,,,,
,52.67,1092,0.0,0.0,22.3,,,,,,,,,,
,53.01,1092,0.2,0.0,23.9,,,,,,,,,,
,53.36,1134,0.4,0.0,21.1,,,,,,,,,,
,53.70,1113,0.2,0.0,23.5,,,,,,,,,,
,54.06,1113,0.2,0.0,21.5,,,,,,,,,,
,54.42,1113,0.2,0.0,24.3,,,,,,,,,,
,54.78,1155,0.4,0.0,22.7,,,,,,,,,,
,55.13,1155,0.4,0.0,22.3,,,,,,,,,,
,55.48,1155,0.4,0.0,21.1,,,,,,,,,,
,55.82,1155,0.4,0.0,22.3,,,,,,,,,,
,56.17,1155,0.7,0.0,23.5,,,,,,,,,,
,56.53,1176,0.7,0.0,21.1,,,,,,,,,,
,56.89,1155,0.7,0.0,21.1,,,,,,,,,,
,57.25,1176,0.7,0.0,21.9,,,,,,,,,,
,57.61,1197,0.9,0.0,21.9,,,,,,,,,,
,57.95,1197,0.9,0.0,20.7,,,,,,,,,,
,58.31,1239,1.1,0.0,20.7,,,,,,,,,,
- goppa
- Автомобил: Seat Alhambra
- Двигател: CFFB
Да вземеш да го приведеш в приличен вид!
- Георги.Георгиев15
Това какво ще рече
- vlado_tonev
- Автомобил: GOLF MK4 1.9TDI
- Двигател: ALH 2000
Почети малко как ср прави лог в движение....
- goppa
- Двигател: CFFB
Георги.Георгиев15 написа:Това какво ще рече
Качи го в табличен вид. Да се вижда кое число какво е. И послушай мнението над моето. Лог се прави при натоварен мотор. В движение, на 4та с пълна газ от 1700 до 4000 оборота, без отпускане на газта.
- Георги.Георгиев15
ето вече лог.п.с кодирах колата на автоматични и сега не забива,а на ръчни забиваше и при хубава центовка,когато истине мотора палеше доста трудно
- Прикачени файлове
- kipvw-rvde1.xls
- (14.5 KиБ) Свален 237 пъти
- goppa
- Двигател: CFFB
Хич не върви тоя голф. 16 секунди от 2400 до 3600 оботота. Имаш някакъв проблем с помпата. Предварението изостава въпреки максималния процент на клапана. Предполагам, че има доста въздух в горивото.
- Георги.Георгиев15
Ами да има.
- vanesto
- Автомобил: Octavia 3 FL
- Двигател: DGTE 2018
- Местоположение: Varna
Или тече помпата, или има клапанче за обратната нафта върху горивния филтър.
- Георги.Георгиев15
Помпата не тече прегледах я обстойно и не нямам клапанче на горивния филтър даже сложих от 2ка, но пак има въздух
- samo_pechka
Тя може да не тече, но виж въздух може да "смуче" . И ако е от семерингата, ще протече и оттам. А протече ли там- става лошо. Имам и съмнението, че си сложил и калпав автърмаркет филтър .
С каква нафта караш? Тубна? Дано е добра , ако е такава.
- goppa
- Двигател: CFFB
Значи маркучите са цепнати или хлабави.
На Голф4 май се прецакваше някакъв о-пръстен на сондата в резервосра. Може и от там да смуче въздух
- samo_pechka
Мхм, няколко са вариантите и ако човек е малко от малко запознат, ще открие проблема
- vanesto
Точно, може да не тече, ама взема въздух. В един момент ще текне.
Потребители, разглеждащи този форум: Няма регистрирани потребители и 194 госта
