части ПОРЪЧКА
- asentm
- airman
- Регистриран на: Вто 16 ное 2004 17:19
ето това което сте ми поръчали и минималните бройки от тях
към цената която знаете има 20 % ДДС + транспорта между 5 и 10 %
казвайте какво да правя че вече ми писна
PERSO minimum
DESCRIPTION
415200001 COUPLING DISC, STEERING SHAFT 30
425201001 STEERING DAMPER 12
498200004 SWAY BAR STABILIZER KIT
511201001 TORSION BAR COVER W/O HOLE 6 broia 2
511200002 BUSHING, SPRING PLATE, OUTER 2broia 10
511225001 BUSHING, SPRING PLATE, L 6broia 10
611201014 C-CLIPS FOR BRAKE 10broia 10
721202001 RETURN SPRING, BRAKE PEDAL 10
823200002 HOOD LOCK CARRIER, LOWER 5
827201004 T-HANDLE FOR ENGINE LID
853201018 VW EMBLEM, GRILLE 3broia 10
845205004 FRONT WINDOW SEAL, OE-STYLE
609201013 HANDBRAKE CABLE, 1752 MM 2broia
AC835001 DOOR HANDLE GUARDS, STAINLESS 2broia
813200003 REAR ENGINE COMPARTMENT SEAL
VW-35021Z EXHAUST KIT, COMPLETE
101225002 SHIM, CYLINDER HEAD, 94X85X1 4broia 10
AC105253 DEGREE CRANK SHAFT PULLEY,BLAC
AC821120 S/S FENDER GUARD, VINTAGE REAR
AC821101 S/S FENDER GUARD, FRONT
AC837822 DOOR COVER GUARDS, STAINLESS
951000-8 FUEL TANK
DENISHEV
598202001 WHEEL BEARING KIT, REAR, 1 WH.
ASEN
AC999105 TAIL LIGHT LENS, CAL LOOK, L/R 2 br 2
AC827980 HINGE EXTENSIONS
AC730001 CUSTOM PEDAL COVER, 3 PCS
AC419000 URETHANE COUPLING, STEERING 2 br 5AC101210 12 V ALTERNATORSTAND, ALU
AC941111 ROSSI HEAD LIGHT RIM, PLASTIC 2 br
598200001 AXLE BOOT KIT, REAR 4 br 10
VW-35060ALT SPORT MANIFOLD
TU219415 HEAD LAMP SET, CLEAR GLASS, H4 2 br
511225001 BUSHING, SPRING PLATE, L 2 br 10
511225002 BUSHING, SPRING PLATE, R 2 br 10
511200002 BUSHING, SPRING PLATE, OUTER 4 br 10
955200008 WIPER BLADE SET, BLACK, 275 MM 2 br 5
VW-35200 MOUNTING KIT, COMPLETE
511201001 TORSION BAR COVER W/O HOLE 2 br 2
831200012 PIN, DOOR HINGE, L/R 2 br 10
831200005 PIN, DOOR HINGE, L/R, STD 2 br 10
831200006 PIN, DOOR HINGE, L/R,+ 0,20 MM 2 br 50AC831203 CAL LOOK WINDOW RUBBER KIT
AC837900 DOOR SILL COVERS
941200002 HEADLAMP HOUSING, US-STYLE 2 br 2
YOKO
129048001 HEATER HOSE, CARDBOARD
837200033 LOCK, VENT WINDOW, L 5
837200028 VENT. WINDOW FRAME W/LOCK, R 2
953200010 SWITCH FOR TURN SIGNAL
YARO
AC109000 'ENGLE' RACING CAM, 6100/W100
AC109300 BOLT-ON STD. CAMSHAFT GEAR
AC109309B CAM GEAR BOLTS (3 PCS.)
VW-35067 SPORT EXHAUST, ORIGINAL
115201001 OIL PUMP COMPL., HD, 30/8 MM
stenly_r
413201002 SHOCK ABSORBER KIT, FRONT 2 br 12
405202007OE BALL JOINT, UPPER, 38.3 MM 2 br
405202009OE BALL JOINT, LOWER, 38.3 MM 2 br
951206-1 RUNNING BOARD 18 MM, L
951206-2 RUNNING BOARD 18 MM, R
898200002 BODY MOULDING KIT
405202003 SEAL, TORSION ARM, LOWER 2 br 10
405202004 SEAL, TRAILING ARM, UPPER 2 br 10
831200011ALT DOOR SEAL, R
831200008ALT DOOR SEAL, L
951098-0 FENDER BEADING 2 br 10
413201002 SHOCK ABSORBER KIT, FRONT 12
857200006 DOOR MIRROR, CHROME, ROUND, L
857200007 DOOR MIRROR, CHROME, ROUND, R
YAGODA
AC867110 HEADLINER KIT, WHITE PERF. VIN
407201001ALT FRONT BRAKE DISC, 9.5 MM 2 br698200004 BRAKE PAD SET, 15.00 MM, FRONT
TONI
957201002 FUEL GAUGE
OBSHTI
AC905500 DISTRIBUTOR CAP, TRANSPARENT 5 br
AC905504 DISTRIBUTOR CAP, RED 5 br
AC905505 DISTRIBUTOR CAP, BLUE 5 br
AC905509 DISTRIBUTOR CAP, SMOKE 5 br
857200006 DOOR MIRROR, CHROME, ROUND, L 2 br
857200007 DOOR MIRROR, CHROME, ROUND, R 2 br
953201011 TURN INDICATOR, BLACK 2 br
PERSO minimum
DESCRIPTION
951000-8 FUEL TANK
DENISHEV
ASEN
YOKO
YARO
stenly_r
YAGODA
TONI
OBSHTI
Последна промяна от asentm на Сря 11 апр 2007 13:58, променено общо 1 път.
- batetony67
- Регистриран на: Сря 09 мар 2005 2:18
- Автомобил: VW Beetle
- Двигател: CU 1980
- asentm
- airman
посредниците си слагат 20%, частите са от Дания и цените които им дават са без тяхното ДДС, което вече се плаща у нас
та сметката е такава към това което имате, то е с посредничесата комисионна трябва сега да качим още 20 % и транспорт
абе хуйня е работата
довечера ще мисля нещо ...а другата седмица ще преговарям да видим очи в очи кво става
тази поръчка я бях пуснал преди ти да заявиш ... виждаш че работат е малко пишман ама кво да правя ...ще взема да се организирам и аз да ги внасям
ще натоварим в понеделник баттони да види как ще е транспорта и ще действаме само май ...ще го мислим
- asentm
- airman
това пак сме ние, но проблема с хофман както и с къстъм парт е, че държат много по-високи цени, доставката е много по бавна, а и частите са същите
давам ти пример че една поръчка от csp-shop.com идва за 4 месеца
те са американски фирми и държат складове на безмитни зони като хонг конг ..поръчваш нещо и те го дърпат от там, ако го нямат в наличност
имам следното предложение
1. от понеделник ще направя един мейл и ще ви кажа паролата, там ще кача ценоразписа, каталога ще е при мен и всеки който е от София ще може да мине да види и да си направи сам поръчката, разберете ме правилно просто извадих си очите докато изкарам номенклатурните №
2. после ще направя връзка с тези фирми от името на клуба и ще взема цени и начини на доставка и ще се оправяме сами без посредници ... разбира се ще има и малка комисионна, защото всеки труд би трябвало да се заплаща
мисля, че ни е нужно да имаме от къде да си вкарваме части, а не всики под път и над път да ни цака
ще помоля бате тони в понеделник да отскочи до посредниците и да се разбере какво точно и как ще стане ...докато си оправим нашите работи, че наистина започна да ми писва от пишман търговци
Асене, какво става с частите?
Ще ги поръчваме ли или да ходя при Гогата?
АЗ НЕ ИСКАМ ДА ПЛАЩАМ ЗА МЕДИЦИТЕ В ЛИБИЯ!
