Кой е любимият ви мотор ?
- znainainai
- Автомобил: Golf4
- Двигател: MK 4 98 AHF
- Madj0
- Регистриран на: Пон 10 апр 2006 13:51
2000 Suzuki Gsx-r 1300 Hayabusa
Manufacturer: Suzuki
Model: GSX-1300R
Engine: Liquid-cooled, inline 4-cylinder, 4-stroke, DOHC
Displacement: 1298 cc
Bore and Stroke: 81.0 x 63.0 mm
Carburetion: Keihin EFI, 46 mm Throttle body
Transmission: 6-speed, constant mesh, wet mulit-plate
Wheelbase: 58.5 in (1485 mm)
Seat Height: 31.7 in (805 mm)
Rake/Trail: 24°/3.8 in (97 mm)
Fuel Capacity: 5.8 gal (22 L)
Oil Capacity; 3.7 qt (3.5 L)
Front Tire: 120/70ZR Bridgestone Battlax BT56 Radial
Rear Tire: 190/50ZR-17 Bridgestone Battlax BT56 Radial
Peak Horspower at crank: 180 hp @ 9800 rpm
Measured Peak Horsepower at wheel: 165 hp @ 9400 rpm
Peak Torque 102 ft-lbs @ 7000 rpm
Claimed Dry Weight: 474 lbs (215 kg)
Measured Wet Weight: 540 lbs (245 kg)
И това
Model: GSX-1300R
И това
Потребители, разглеждащи този форум: Няма регистрирани потребители и 257 госта
170 k.c
