Малките дупки ги почистих, но с игла, че не намерих толкова тънка медна тел.
А контактите ги гледах, май са на принципа "има-няма" най-обикновени прекъсвачи и работят ОК, въпросът е че пластината (№ 4) която трябва да натиска единия прекъсвач (№ 2) въобще не го достига след регулирането на оборотите?
RPM - Jetta2 - Вдигане на оборотите.
Re: ? за RPM при студен двигател (Jetta 2)
Да си отговоря сам на въпросите
След малко четене се оказа, че оборотите не се регулират от болт № 1 на снимката!!!
Извод: Внимавайте чии съвети слушате!
Throttle valve switches - testing and adjustment (№ 2 и 3 на снимката)
1 There are two throttle valve switches.
Switch 1 monitors the throttle valve closed position and switch 2 monitors the throttle valve fully open positio (see illustration).
2 Disconnect the supply plug from switch 2 and check that approximately 5 volts is available across the two terminals with the ignition switched on. If not, check the wiring from the control unit.
3 Connect an ohmmeter across the terminals of switch 2, then slowly open the throttle valve until the switch points close. The gap at the throttle lever stop must be 0.20 to 0.60 mm when the points close. If necessary, adjust the position of switch 1.
4 A piece of card marked with 10° is required to check switch 2. Attach the card to the first stage throttle valve shaft.
5 Fully open the throttle and align a datum with 0° on the card. Close the throttle by approximately 20°, then slowly open it until switch 2 points close. This should occur at 10° ± 2° before full throttle. If necessary, adjust the position of switch 2. Note that the throttle valve lever roller must contact the sloping part of switch 2 (№ 3 на снимката).
Throttle stop - adjustment (№ 1 на снимката)
1 Throttle stop adjustment is initially set at the factory and should not be tampered with.
However, if it is accidentally disturbed, proceed as follows.
2 Back off the adjustment screw until a gap exists between the carrier lever and stop lever (see illustration).
3 Turn the adjustment screw until the two levers just make contact, then continue to turn it a further half-turn. Tighten the locknut.
4 After making an adjustment, readjust the throttle valve switches, and the idle speed and mixture.
- radotom
- Модератор
- Автомобил: Passat B6
- Двигател: CBBB
3 е вакуум, да. И доколкото виждам е скъсан. Смени тръбичката, иначе регулатора на налягането на бензина няма да си върши работата.
2 също е вакуум, впрочем
1 на снимаката е дроселен винт на байпасния канал на дроселовата клапа (мноооого объркано излезе!
) Нищо, де! За него после.
Стопорния винт на дросела ти е болтчето за ключ 8 най-отгоре, дето има и стопорна гайка.
Този болт го нагласяш така, че клапата да може да бъде почти напълно затворена.
Лично аз съм го оставил да има около 0.5-0.7мм просвет.
Сменяш вакуумните маркучлета, за да работи регулатора на налягането и си настройваш датчика за празен ход да сработва, когато клапата е опряла в стопора горе.
След това отвиваш бавно дроселния винт, който на снимката е означен с жълта стрела под №1 докато получиш минималните стабилни обороти.
Специално аз настройката на този винт я правих на леко прогрят мотор, около 40*-50*С и се получи.
По книга май дават, че трябва да е напълно загрял мотора, но аз проблем с оборотите имах точно в този диапазон - от 40* до 65*, за това и така го правех.
Аха!
Писал си, докато и аз съм писал
Точно на новите снимки червения №1 е стопорния болт. Ама никой не е твърдял, че той е за настройка на оборотите
Вече явно знаеш, че за тази цел е червения №5
Та тъй, де!
Нагласи ли датчика №2 да задейства, когато си отпуснал газта?
) Нищо, де! За него после.Стопорния винт на дросела ти е болтчето за ключ 8 най-отгоре, дето има и стопорна гайка.
Аха!
Та тъй, де!
След настройкта на стопорният и дроселният винт, и почистването на дроселната клапа,
сега работи значително по-добре!!!!
Специални Благодарности на Radotom и Iezekil
Сега вече не е необходимо да държа 5 минути газ и спирачка докато загрее,
но за да запали пак трябва да натисна газта?
Някакви идеи какво още трябва да се бъзикне, че да се оправи съвсем?
Само малката клапа ли трябва да е леко отворена, моята и оставих към 0.5 мм дупка - където е червената стрелка?
ПП един "специалист" ме подведе преди години че стопорният винт е за оборотите на празен ход, и аз връткам ли връткам....
- radotom
- Модератор
- Двигател: CBBB
x15 написа:Някакви идеи какво още трябва да се бъзикне, че да се оправи съвсем?
Оправи ли вакуумчето към дросела?
Макар, че не е от него проблема с паленето, де! Той почва да играе след като запалиш.
На снимките от предходната страница се вижда горивната рейка. Вижда се и един щуцер, който при 2Е захранва с гориво дюзата за студен старт, а при теб изглежда стърчаща във въздуха...
Ясно, че не е така - иначе скоростната ти кутия щеше да е перфектно чиста и постоянно да се мие от извиращия от щуцера бензин, ама... какво има там?
За дросела съм пас, защото на 2Е е само 1 голяма клапа, но предполагам, че при теб първо отваря малката, след това голямата, така, че да, само тя трябва да е открехната
Вакумчето на дросела го накъсих малко, докато си намеря нова тръбичка.
Ъъъъъ... какво е горивната рейка, Вижда се и един щуцер..... ?
Признавам си... повечето термини не ги знам
- Iezekil
- Двигател: ABS 94
- Местоположение: Шумен
да,той щуцер си е тъй на тия мотори дето са.... с клапан за картерна вентилация...вече се насочи към него.Платното трябва да е здраво,понеже влияе пряко на дросела,в смисъл че пропуска не отчетен от дебитомера възду.Ако е разрушен и просто за тест по добре го откачи.Иначе за палене без натисната газ ми се струва,че ще решиш проблема с малко предварение на делкото...
Клапан за картерна вентилация онова кръглото дето съм го лепил със силикон ли беше? Ако го откача трябва ли да запушвам дупките? Как да го разбера дали е добре?
Горивната рейка това на което са закачени инжекторите ли е?
Къде се намира дюзата за студент старт?
- Iezekil
- Двигател: ABS 94
ти май нямаш 5-та дюза,намира се в дясно на колекторите хванат -маркуч за бензин с куплунг включен в него...син.Сега се загледах в щуцера,не е за 5-та дюза,сяккаш виждам че отт него продължава маркучБи ли го проследил??
Щуцер № 9 от снимката по-горе е изцяло метална тръба която отива между двигателя и купето,не и се вижда краят, но с напипване бих казал че отива в смукателният колектор, синъо-зеленият край който се вижда на снимката не е маркуч, а тапа. До задният край на щуцер № 9 има някакъв сензор с три кабелчета, но не се вижда?
- Iezekil
- Двигател: ABS 94
щуцер 9 го имат и двигателите с 5-та дюза,само че е малко по-назад.Не знам каква работа върши.Става въпрос за щуцера от ляво на щуцер 9,успоредния на бензиновата рейка/май/
Ако става въпрос за № 15 на втората снимка, това е въздух от байпаса.
- сложих номера на различните чаркове, че като не им знам имената...
- radotom
- Модератор
- Двигател: CBBB
Хъ т'къв!
Щуцера, за който ми стана интересно е под №3 на първата снимка.
№4 е горивната рейка, там, дето са дюзите, да. И ако при мен този щуцер остане така, както е при теб - цвърчи бензин яко!
Макар, че тази сутрин при мен се разцвърча от другата страна, на входа
... гадна скобичка на маркуча иии...
Синьо-зелената тапичка под №9 ти е тръбичка о изпускателния колектор и доколкото съм чувал от там се пъхала сондата при проверка на изгорелите газове (при технически преглед, примерно)
А сепаратора на картерната вентилация е лепеното със силикон под №10
Сепаратора на картерната вентилация изглежда залепен отвсякъде, има ли начин да се провери без да се реже?
Какво още да гледам с което може да се подобри работата на двигателя?
- Iezekil
- Двигател: ABS 94
да,проследи го този маркуч о тномер 3 на първата и номер 16 на втората снимка.Клапана за картерната вентилация трябва да може да се разглоби за да се види вътре платното на кво дереже е.и дай най-после малко предварение,да видим разлика в паленето ще има ли
