zarka.zlobarka написа:Ехехееей опасни сте.Колко бързо похарчихте едни 300лв ..
Може и да не стигнат.
вместо да се любуваме на хубавата кола, която със 18" e направо убиец
Bigger is not always better:
Putting bigger brakes on may not always be a good idea.
For chipped/re-mapped cars the obvious upgrade is 312mm fronts because it's so easy.
But, putting the 312mm conversion on a 1.4 for example, along with bigger wheels than standard and you will be adding alot of weight to your wheels, and the engine will be put under more strain, therefore reducing your accelleration.
And Big brakes, contrary to popular beleif, don't actually do as much as people think in terms of stopping power increase, it's mainly that the disc heats up less, cools faster and therefore can stop the car more effectively, corner after corner without getting brake fade.
The best brake mod for the smaller engined cars would be Performance pads and Performance Brake fluid, I wouldn't bother with drilled and grooved discs.
silven-VW FOREVER написа:както е казал Мечо Пух "Колкото повече толкова повече"![]()
Потребители, разглеждащи този форум: bongoo и 30 госта
