п.с. Речника ми има доста повече от 2000 чужди думи и то не само на английски!
The P1000 DTC code is a manufacturer specific code. In the case of Ford vehicles, it simply means that the OBD-II monitor testing is not complete. It is a similar meaning for Mazda, which is OBD-II drive cycle malfunction. If an OBD-II monitor does not carry out their full diagnostic check, this DTC may be set also.
