Vlad777 написа: 250000 км за ремъка на маслената помпа в картера
netizen написа:...което за мен означава, че е добре да се смени заедно с ангренажа.
Activation conditions: The electrical auxiliary air heater is activated:
• in the case of the Climatronic and Climatic systems, automatically via the CAN data bus.
• if the occupants set the heating output to over 90 per cent at the operating unit.
• if the water temperature is below 75 degrees Celsius.
• if the engine speed is higher than 500rpm.
• if no load management system is active.
• if the ‘Econ’ button is not pressed.
